Quake LED plug and play retrofit JL LED Headlight and Fog Lights
Quake LED
Summit Sponsor (Level 3)
Mr. Black
Denver
quakeled.com
JK, JL
Sweat Shop Manger, Slum Lord and Break Dancer
First to market! Sit back and relax JL owners. Our aftermarket plug and play retrofit JL LED Headlight and Fog Lights are here and packed full of features that other so-called LED companies haven’t even dreamt about yet.
This patent pending design headlight comes stock with adjustable High/Low beams, DRL Accent Lighting (Bluetooth controler included), built in Amber Turn Signals and real high power 5W Osram Diodes all jamming through a 4D projector lens design. Our impact resistant aluminum optic ring design provides a watertight seal. Built in our German TUV approved factory and not someone else’s. Quake LED only uses High Quality Diodes, PCB Boards, Resistors and oversized off-road durable Wiring. Durable powder coating and marine grade epoxies will provide you with the comfort of knowing this light will last as long your Jeep does. Try saying that about those mass-produced, el cheapo lights found on the Internet. You get what you pay for.
These easy to install headlights connect with Quake LED’s Easy Link, Quad-Lock Pro and Interlock Controllers giving you endless linking and control possibilities.
LED Head Lights - In-stock
https://quakeled.com/shop/jeep-jl-led-headlight-w-turn-signal-direct-replacement-75-watt-rgb-accent/
LED Fog Lights - In-stock
https://quakeled.com/shop/jeep-jl-led-fog-light-direct-replacement-30-watt-rgb-accent/
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
Looks great, congrats to be the first to the market! Tempting for my wife's sport since I can then cut her fenders(since the blinkers will be built into the headlights) for better clearance and give her my 37's :like:
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
So are these truly plug and play as it unplug my halogen ones and plug in the LEDS
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
Thanks! Yes these have a built in Amber Turn Signal that you can tap into your turn signal feed. No errors will trigger. I just updated the ad to show the amber turn signal feature as we have had many enquires about it. Let me know if you have any other questions.
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
Hello and thanks for your question. Yes we built our JL headlights with the same connector as your stock light. You will not need to cut and splice any wires. Best Regards and let me know if you have any other questions.
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
Thanks for the response.
If I eliminate the factory signals when I trim the fenders I'm sure I will need to do something for it to not trigger the light out warning/fastblink?
WranglerMan
Will
Katy Texas
Gas Pipeliner
I hate to keep asking questions but I currently have the halogen Mopar factory ones and non led factory fogs so I can just but these and swap them out by unplugging and plugging in correct, I’m not real good doing electrical on vehicles and never liked the idea of cutting into and spicing wires so if these are just unplug the non LED stuff I have and plug in these with cutting and splicing that would be pretty cool and these are DOT approved for running down the road right ?
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
Hi again. I've asked our lead engineer and he says since you're removing the stock fenders. You would tap our headlight Amber turn signal feed into the one that was on the stock fender. You will not have any warning issues.
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
Ask the engineer if he can send me a set to test/verify :giggle:
I need to bring my wifes Jeep to the shop with me and take out the fender liners to figure out how I can cut the fenders while keeping a semi factory look. I planned on giving her my Rubicon flares/indicators when I upgrade to steel flat fenders, but I like this alternative.:like:
Bswen
Atlanta
2018 JL Sahara
1) are they DOT approved or for off-road use only?
2) When on your website and getting ready to order it does not ask whether I currently have LEDs or Halogens. Jeeps with LEDs vs Halogens have a different connector (at least that is the impression I am under). Are these made for JLs with Halogens specifically?
Archer85
Tampa, FL
2018 Wrangler JL Sport S
On the link there is nothing about the amber turn signals, no pics of them. Will there be a video released of this? for $600 id expect more than 6 basic pics and limited description.
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
DOT not a problem - We used these on lots of different models of JL's Our tests and Intel tells us that there is only one connector type either it be halogen or LED. Also we have been shipping these lights to customers and we have not heard any complaints in regards to the lights, especially a connector issue.
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
Sorry for that. Yes video coming soon. We released with Limited marketing so the release wouldn't be delayed. We are releasing more content everyday and i am sure you will see customers review on here too.
Specter491
'18 Wranlger JL Sport S
The led and halogen fog lights use different mounting brackets on the bumpers. Do these lights fit on the halogen bumper/brackets?
