Very nice, thank you for the picture Jession!Quake Quad Lock system, headlights, fog lights rock lights, 3” cubes, 52” light bar, universal led controller
Any discounts for the combo package right now?https://www.jlwranglerforums.com/fo...back-turn-signal-headlights-fog-lights.19922/
completely plug and play halos now available for under 400 shipped!
Just remember, these are actually 7” headlights in a 9” mounting. So technically they are not true 9” lights. But since they are projectors, I dont think it really matters. The Halo is smaller than a true 9”. I still like them. Got the Headlights used on the forum here. May add the fogs later.Any discounts for the combo package right now?
I like the look of them on your jeep! Mine is mojito as well. i agree it shouldnt make a difference on a projector headlight.Just remember, these are actually 7” headlights in a 9” mounting. So technically they are not true 9” lights. But since they are projectors, I dont think it really matters. The Halo is smaller than a true 9”. I still like them. Got the Headlights used on the forum here. May add the fogs later.
If you get them, dont do like I did and follow the instructions for accessing the signal wire for the amber halo turn. Take the fenders off as shown in the video below. Its worth it.I like the look of them on your jeep! Mine is mojito as well. i agree it shouldnt make a difference on a projector headlight.
I wish I'd seen this before I did my install. Everything else was easy but accessing the turn signal halo was huge pain in the a$$.If you get them, dont do like I did and follow the instructions for accessing the signal wire for the amber halo turn. Take the fenders off as shown in the video below. Its worth it.
I apologize. We did not show this method because the body retention clips almost always break when you pull the fender off. They were not available to buy yet unless you bought the whole fender. They are now available for under a buck a piece so the new install will give this option for install.I wish I'd seen this before I did my install. Everything else was easy but accessing the turn signal halo was huge pain in the a$$.
hi it's Tony, how much do you want for your old factory LEDs? Would love to buy them. Thanks for your time.On to running RGB wires. I stuck the controller on top of the fender with the supplied 3M tape. Used the 10 min to take out an air box bolt to run them underneath it to make it look clean. Then ran 2 wires to the passenger side for the fog light and headlight then underneath the plastic should on top of the radiator support to the driver lights. I plugged in the RGBs to the headlights plugged the headlights into the factory harness and screwed the headlights in.
No worries.I apologize. We did not show this method because the body retention clips almost always break when you pull the fender off. They were not available to buy yet unless you bought the whole fender. They are now available for under a buck a piece so the new install will give this option for install.
Whatever doesnt kill you makes you strongerI wish I'd seen this before I did my install. Everything else was easy but accessing the turn signal halo was huge pain in the a$$.
Nice. Waiting on my fogs to arriveQuake LED headlights and fog lights with halos finally installed. No complaints so far. Rob at Quake was awesome the way customer service should be.
