otisroy
No, I wouldn't say true plug and play. Those of us with halogens don't have the fourth pin in the headlight connector to power the halo. The halo is powered by the controller. You have to get power to the controller, easy enough if you have the AUX switches. Then you run a set of cables from the controller to the headlights and fogs if you swap those. The hardest part of the install was getting to the turn signal wires for the T-taps.
If you skip the turn signal taps you could probably do the whole thing in half an hour. Add a few more minutes if you undo all of the clips in the cable trough on the firewall to route your cables that way.
