10AM
- Alex
- May 23, 2019
- Naperville
- 2018 Wrangler JLU Sport S
Ordered a pair of Quake LEDs over the winter but ended up trading the JL in for a JT with factory LEDs. These were never installed or opened. List for $399. Asking $200
Willing to ship at buyers expense
https://quakeled.com/jeep-wrangler-...ite-drl-halo-amber-turn-signal-quake-led.html
Enhanced visibility for a safer ride home. Quake Tempest LEDs feature high output, Quake Tempest headlamps are perfect for replacing halogens with a more effective light beam and uses less power due to a low current draw.
Construction Quake Tempest LED Lights provide a solid-state, bulb-free headlamp design that is waterproof and extremely durable against damage from shock and vibration. Quake Tempest LEDs are constructed using military grade, die-cast aluminum housing and non-yellowing, polycarbonate lenses to offer optimum protection against damage from impact, roadside debris, and other hazards.
This light is sealed by reinforcement grade epoxy that resists damage caused by corrosion or moisture, along with advanced circuitry to protect against voltage spikes. Using standard H4, 3-blade wiring connector, its easy to fit and connect the Quake Tempest Series lights to existing mountings without the hassle of a complicated retrofit.
Applications Crafted to provide superior performance for all on and off road vehicles including; trucks, agricultural vehicles, mining equipment, and vintage and new cars. Ideal for additional headlight lighting possibilities for the next Quake adventure.
Features:
Features:
- 9 Inch
- Sold as pair
- High/Low Beam
- Black Reflector
- Beam Color: Bright White
- Function: White Halo DRL with Amber Turn Signal
- 3 pcs 10 Watt Cree
- Lumens 1,500
- Operating Voltage: 10-30V DC
- Operating Temp: -40 to 140 degrees F
- Waterproof Rating IP67
- Diecast Aluminum
- Mounting Hardware: Steel
- About 50,000 hours life time
