Andrew2311
Is there a way to permanently disable that auto stop/start function without having to remember to hit that stupid button every time?
yes, and it works perfectly. just remember to remove it before heading to the dealer for service.Is there a way to permanently disable that auto stop/start function without having to remember to hit that stupid button every time?
Anyone have recommendations for quality 2 way radios? This isn't actually for jeep reasons. My wife and I own a small preschool, but the campus is spread out and we need them for communication. Has to hold up to daily use, communicate across about 100 yds and through block walls, and good squelch control. The ones I got before aren't holding up, dead batteries and such. I'd be looking to buy 6. I obviously am looking for the most bang for the buck. Hope someone can help. Thanks!
I though you needed some kind of Magic Kingdom license to transmit on that band?
Link?
I have some Midland GXT1000 radios, they're not too bad. They have plenty of range for what you need and are pretty solidly built.Anyone have recommendations for quality 2 way radios? This isn't actually for jeep reasons. My wife and I own a small preschool, but the campus is spread out and we need them for communication. Has to hold up to daily use, communicate across about 100 yds and through block walls, and good squelch control. The ones I got before aren't holding up, dead batteries and such. I'd be looking to buy 6. I obviously am looking for the most bang for the buck. Hope someone can help. Thanks!
Thanks. I'd been doing a little research and had those on my radar. I put in the order.I have some Midland GXT1000 radios, they're not too bad. They have plenty of range for what you need and are pretty solidly built.
You can get a 6 pack on Amazon for $220.
https://www.amazon.com/dp/B01786WDT4/ref=cm_sw_r_cp_api_i_9vQeDb0MS8R95
There’s a thread on that somewhere around here, but I think it’s practically impossible. It would probably require programming of the ECU.Anyone?
Have you had a remote start on a manual transmission before? They are a very different procedure. You usually have to prep the vehicle for remote before it's turned off, then exit, lock and shutdown with the remote. That being said, it would make the factory remote impossible to use with a manual.Can you make the mopar remote start work with the 6sp if you buy it aftermarket and install it yourself? Obviously, you could never leave the tranny in gear, but I never do that anyways.
1. The factory Rubicon 33" tires with rub with Sahara or Sport fenders. You'll need at least a 1" spacer lift to get them under there. Rubicon fenders are higher, and the axles are wider.I'm a Jeep noob (never owned one before, but I really want a JLUR) so I'm glad there is a thread for just these type of questions.
Forgive me if these have been asked elsewhere..
I hear you @MrMischief. Normally you'd be absolutely right and I'd agree with you.Can you take the door off and put it back on with how it is now? If so, I don't see any reason to "fix" it
