QTDDTOT: Questions that don't deserve their own thread
homerun
Fort Collins, Colorado
1996 XJ, 2004 Ford Ranger, 2013 Subaru Impreza, 1996 HD Springer Softtail, past jeep 1995 YJ
Hi again. I’m renting a JLU Sport for a week in order to see whether I might want to buy one.
It has the 4-position transfer case — 2H, 4H, N, 4L. I have tried shifting the case, and haven’t been able to. I DLed the owner’s manual, which says that with the vehicle standing still (or at low speed) and with steady pressure on the stick, it should move.
Am I missing something, or has AVIS put some kind of lock on the case?
It is very stiff at first, that said transmission in neutral, and vehicle rolling. Much harder to do at a dead stop. The tcase does not have synchros like the transmission, therefore moving will help with alignment.
homerun
We rented a Nissan Armada and the 4WD switch there is a big volume-looking knob on the center console. That takes absolutely no effort to engage into 4H. They at least add a step to go into 4L.
But the Nissan was electric and not mechanical. How many times you see guys rocking from 1st to reverse trying to get out of 4wd? I would much prefer the mechanical mechanism.
TRZ
Tom
Denver, Colorado
2019 JLUR, Ocean Blue
You think so? The Wildpeak M/Ts have received great reviews, including snow and ice, for several years now. They carry a M+S rating which I believe permits you to use them on I-70 in the winter. Sure they're not as good as the snowflake/three peak rating on the BFG KO2s, but I'm expecting the Wildpeak M/Ts to be just fine this winter.
I’m far from an expert on this, but how is this tread going to be good on ice (under the snow)?
The Wildpeak’s do seem to have good reviews for snow (and presumably ice) I just don’t see how they can be that good.
AustinL911
Austin
Central Ohio
2007 Cheby Colorado
Can you make the mopar remote start work with the 6sp if you buy it aftermarket and install it yourself? Obviously, you could never leave the tranny in gear, but I never do that anyways.
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU Sport
Here's a new question about Tip Start. For those who don't know what that is, it's a feature where you press the start button momentarily and the engine starter operates automatically until the engine starts. My JL doesn't have this so I have to hold the start button until the engine starts before I release it. I'm guessing manual transmission models (like mine) don't have Tip Start for safety reasons in case the shifter is in gear. Do you guys/gals have Tip Start on your Auto JLs? Or is it a trim level feature? Does anyone with a manual transmission have it?
Rufus
NYC
2018 2 door JL Sport 3.6 V6
It is because you have a manual, as do I. This was explained to me by the dealer when I picked it up.
Rahneld
Ronald
Boston
JL Wrangler
Which top for the Wrangler JL is furthest from the ground as measured on the same JL, the premium soft top or the hard top?
I've got some cross members above my hard top that just clear it. I'm trying to figure if they'll get in the way when I install the soft top.
Thanks. Forget that the soft top opens. I'm just interested in height for now.
robaw
Rob
Iowa
From my measurements, at the highest point the premium soft top is approx. 3" higher than the hard top.
Rahneld
Ronald
Boston
JL Wrangler
Thanks Rob, but there are also places where it's maybe two inches lower or so, right?
That's where I can run cross members. Thanks for checking this for me. : - )
Pilotjeep
Pete
NYC
Hyundai Elantra Touring, future Jeep?
Thanks to those who answered my previous question. I was able to shift the transfer case of my rental out of 2H, and I'm pretty sure that first shift took more effort than the ones after. At least it seemed that way.
four low
central New York
2018 JL
Would Jeep ever create a 2 door extended wheelbase JL (LL) like the old LJs?
I hope so ! The 4 Dr is too long, an extended version like the LJ would be great.
The LJs are highly sought after now. If not the pictured version, then maybe a 2 door JT, call it "Scrambler" . Fingers Crossed...
Pilotjeep
Pete
NYC
Okay, here’s another one. Is there a reason selecting heated seats and steering wheel forces a switch from all-season to all-terrain tires?
lookitsadam
Tampa, Florida
2018 JLU Sport
The J6 concept at East Jeep Safari this year is basically a 2 door JT with the same wheelbase as a JLU. My dream. Hopefully they make it production Jeep, or offer a conversion kit.
Hothead Headliners
