Q: 2020 JLU OEM 18" tires as delivered
Pilotjeep
Pete
NYC
Hyundai Elantra Touring, future Jeep?
I'm trying to find out whether I got the right tires on my 2020 JLU Sahara from the factory. It has the 18" wheels.
Here's the possible issue:
On both the Jeep Order Guide, and with the online build configurator, it says that when you get the Anti-spin rear differential option, it includes "All-terrain tires" or "255/70R18 All-Terrain Tires." This applies for both the Sahara and the Sahara Altitude. (It could apply for other variants too, I haven't checked.)
Mine, which has the anti-spin diff, was delivered with Bridgestone Dueler H/T 685 113T's. They have a standard highway tread pattern, which looks like it will be worthless in snow. I wanted the AS diff and the tires so I wouldn't have to worry for driving to winter sports.
Tire Rack describes the Dueler H/T as "Highway All-season," and calls two versions of the Dueler A/T "On/Off Road All-Terrain." So, I am thinking that Jeep is delivering vehicles with the wrong, standard tires when the AS diff is ordered.
So, my question is this: on your 2020 JLU Sahara with 18" wheels,
1. do you have the standard rear diff or the anti-slip rear diff, and
2. what tires did it come with?
I want to know if FCA is pulling a fast one by supplying the same tires for both. If so, I want to get my proper tires. Thanks.
entropy
Pasadena
Jeep Wrangler Sport S JL 2-D
Data Scientist
anti-spin rear diff your Jeep should have come with A/T and not H/T. Go back to the dealer and have them check and make sure you got the dana 44 axles with the anti-slip diff and if they got that right claim your A/T tires. My sport came with the Wrangler Kevlar A/T tires.
  • Like
Reactions: zyt
TrailTorque
JLU
Pilotjeep
Pete
NYC
@Pilotjeep
Why don’t you start by posting your build sheet here. Then we can go from there.
Replace the “X’s” with your VIN number.
https://www.jeep.com/webselfservice/BuildSheetServlet?vin=XXXXXXXXXXXXXXXXX
The build sheet specifies anti-slip diff, but Bridgestone all-season tires
Equipment Listing
VIN 1C4HJXEN3LW152997
Vehicle Description 2020 JEEP WRANGLER UNLIMITED SAHARA
STANDARD EQUIPMENT
  • * Technology Group
  • * Single Top Package
  • * Monotone Paint
  • * Electronic Stability Control
  • * Hill Start Assist
  • * Traction Control
  • * Electronic Roll Mitigation
  • * Trailer Sway Damping
  • * Hydraulic Assist Brake Booster
  • * Anti-Lock 4-Wheel Disc HD Brakes
  • * Low Back Bucket Seats
  • * Reclining Front Seats
  • * Driver Height Adjuster Seat
  • * Rear 60/40 Folding Seat
  • * Child Seat Upper Tether Anchorage
  • * RR Head Restraints Outboard Seating
  • * Advanced Multistage Front Air Bags
  • * Supplemental Frt Seat Side Air Bags
  • * Front Seat Area Carpet
  • * Rear Seat/Wheelhouse/Cargo Carpet
  • * Cargo Tie Down Loops
  • * Sport Bar
  • * Three Rear Seat Head Restraints
  • * Front Seat Back Map Pockets
1 11/03/19
  • * Driver and Passenger Assist Handles
  • * Full Length Floor Console
  • * Rear Compartment Storage Tray
  • * Storage Tray
  • * Illuminated Cupholders
  • * Dana M186 Front Axle
  • * 3.45 Overall Top Gear Ratio
  • * Dana M220 Rear Axle
  • * Conventional Differential Frt Axle
  • * Tinted Windshield Glass
  • * Front Door Tinted Glass
  • * Deep Tint Sunscreen Windows
  • * Full Metal Doors w/Roll-up Windows
  • * Sun Visors w/Illum Vanity Mirrors
  • * Power Heated Mirrors
  • * Remote Keyless Entry
  • * Sentry Key Theft Deterrent System
  • * Pushbutton Start
  • * Air Conditioning w/Auto Temp Control
  • * Hood Insulation
  • * Cluster 7.0" TFT Color Display
  • * 120 MPH Primary Speedometer
  • * Outside Temperature Gauge
  • * Var Intermittent Windshield Wipers
  • * Dual Note Electric Horns
  • * 12V Auxiliary Power Outlet
  • * Auxiliary 12-Volt Rear Power Outlet
  • * Locking Glove Box
  • * 115V Auxiliary Power Outlet
2 11/03/19
  • * Speed Sensitive Power Locks
  • * Pwr Windows, Front 1-Touch Down
  • * Manual 2-Way Driver Lumbar Adjust
  • * Manual 6-Way Driver Seat
  • * Frt Pass Seat - Manual Adjust 4-Way
  • * Front Passenger Seat Belt Alert
  • * Vehicle Information Center
  • * Courtesy Lamps
  • * Front Dome w/On/Off Switch Lamp
  • * Console Bin Task Light
  • * Black Exterior Mirrors
  • * Ambient LED Interior Lighting
  • * Headlamp Off Time Delay
  • * Rear Dome w/On/Off Switch Lamp
  • * Automatic Headlamps
  • * Ft Side Marker/Side Repeater Lamp
  • * CHMSL Lamp
  • * Security Alarm
  • * Injection Molded Black Rear Bumper
  • * Black Front Frame Overlay
  • * Wrangler Decal
  • * Body Color Fender Flares
  • * Black Door Handles
  • * Side Steps
  • * Trail Rated Badge
  • * 21.5 Gallon Fuel Tank
  • * Firecracker Red C/C
  • * Fixed Long Mast Antenna
  • * Steering Wheel Mounted Audio Ctrls
3 11/03/19
  • * Media Hub (USB, Aux)
  • * Audio Jack Input for Mobile Devices
  • * Remote USB Port
  • * Remote USB Port - Charge Only
  • * Dual Remote USB Port - Charge Only
  • * Power Steering
  • * Heavy Duty Suspension w/Gas Shocks
  • * Front Stabilizer Bar
  • * Rear Stabilizer Bar
  • * Tilt/Telescope Steering Column
  • * Full Size Spare Tire
  • * Outside Tire Carrier
  • * 255/70R18 All Season Tires
  • * Matching Spare Wheel
  • * ParkView Rear Back-up Camera
  • * Occupant Classification System
  • * Fuel Tank Skid Plate Shield
  • * Transfer Case Skid Plate Shield
  • * 2 Front & 1 Rear Tow Hooks
  • * Torx Tool Kit
  • * Transmission Skid Plate
  • * R1234YF A/C Refrigerant
  • * Universal Garage Door Opener
  • * Tire Pressure Monitoring Display
  • * Tethered Fuel Filler Cap
  • * Black Fuel Filler Door
  • * English/USA Language
  • * Protective Coating and Remover
  • * Bumper Module I
4 11/03/19
  • * Wheel Flare/DRL Parts Module
  • * Grille Module
  • * Door Trim Panel Module
  • * Glass Module
  • * Center Console Parts Module
  • * Front Fascias Parts Module
  • * Seat Parts Module
  • * Instrument Panel Parts Module
  • * Door Parts Module
  • * Front End Parts Module
  • * Front Suspension Parts Module
  • * Rear Suspension Parts Module
  • * Tire & Wheel Parts Module
  • * Frame Parts Module
  • * Build To U.S. Mkt. Specifications
  • * GVW Rating - 5500#
  • * U.S. Dealer Retail
  • * Zone 32-New York
  • * JL/5403 Vehicle Family
  • * Four Wheel Drive (4WD)/(4X4)
  • * Left Hand Drive (LHD)
  • * 2020 Vehicle Specifications
  • * Price Class P
  • * Four Door
  • * Vehicle Order Tracking
  • * Long Wheel Base (LWB)
  • * U.S. Specifications Label
  • * Connecticut Ship to State Code
  • * Connecticut Sold to State Code
5 11/03/19
OPTIONAL EQUIPMENT
  • * Leather Trimmed Bucket Seats
  • * Black
  • * Cold Weather Group
  • * Trailer Tow and HD Electrical Group
  • * LED Lighting Group
  • * 8.4" Radio and Premium Audio Group
  • * Altitude Package
  • * Safety Group
  • * Advanced Safety Group
  • * Delete Alternator
  • * 700 Amp Maintenance Free Battery
  • * Advanced Brake Assist
  • * Hill Descent Control
  • * MOPAR Hardtop Headliner
  • * Cargo Compartment Floor Mat
  • * MOPAR Cargo Tub Liner
  • * MOPAR Plastic Door Sill Guards
  • * Cargo Group w/ Trail Rail System
  • * Freedom Panel Storage Bag
  • * Leather Wrapped Park Brake Handle
  • * Leather Wrapped Shift Knob
  • * MOPAR All-Weather Floor Mats
  • * #1 Seat Foam Cushion
  • * All Automatic Transmissions
  • * 8-Spd Auto 850RE Trans (Make)
  • * 2.72:1 Selec-Trac Full Time 4WD Sys
  • * Anti-Spin Differential Rear Axle
6 11/03/19
  • * 2.0L I4 DOHC DI Turbo eTorque Engine
  • * Rear Window Defroster
  • * Rear View Auto Dim Mirror
  • * Remote Proximity Keyless Entry
  • * Body Color 3-Piece Hard Top
  • * Gloss Black Instrument Panel Bezels
  • * Rear Window Wiper/Washer
  • * 110mph Vehicle Max Speed Calibration
  • * GPS Navigation
  • * GPS Antenna Input
  • * Active Noise Control System
  • * Air Filtering
  • * Heated Front Seats
  • * LED Taillamps
  • * Aux Switches
  • * Auto High Beam Headlamp Control
  • * Front LED Fog Lamps
  • * LED Reflector Headlamps
  • * Daytime Running Lamp LED Accents
  • * Full Speed Fwd Collision Warn Plus
  • * Mold in Color Bumper w/Gloss Black
  • * Front License Plate Bracket
  • * Body Color Grille w/Gloss Black
  • * Matte Black Jeep Badge
  • * 50 State Emissions
  • * Heated Steering Wheel
  • * Adaptive Cruise Control w/Stop
  • * All Radio Equipped Vehicles
7 11/03/19
  • * Alpine Premium Audio System
  • * HD Radio
  • * 8.4" Touchscreen Display
  • * Apple CarPlay
  • * Google Android Auto
  • * USB Host Flip
  • * SiriusXM Satellite Radio
  • * SiriusXM Guardian, 1-Yr Trial
  • * SiriusXM Travel Link
  • * Emergency / Assistance Call
  • * SiriusXM Traffic Plus
  • * Integrated Center Stack Radio
  • * 4G LTE Wi-Fi Hot Spot
  • * Leather Wrapped Steering Wheel
  • * No Soft Top
  • * Bridgestone Brand Tires
  • * Uconnect 4C NAV with 8.4" Display
  • * 18X7.5 Gloss Black Alum Wheels
  • * All Aluminum Wheels
  • * ParkSense Rear Park Assist System
  • * Blind Spot and Cross Path Detection
  • * Remote Start System
  • * Tip Start
  • * 48V Belt Starter Generator
  • * Class II Receiver Hitch
  • * 7 and 4 Pin Wiring Harness
  • * Non-Lock Fuel Cap w/o Discriminator
  • * Integrated Voice Command w/Bluetooth
  • * Black Interior Accents
8 11/03/19
  • * 1-Yr. SiriusXM Radio Service
  • * For Details, Visit DriveUconnect.com
  • * For More Info, Call 800-643-2112
  • * 5-Year SiriusXM Traffic Service
  • * 5-Year SiriusXM Travel Link Service
  • * 4 Additional Gallons of Gas
  • * Spring - Left Front
  • * Spring - Left Rear
  • * Spring - Right Front
  • * Spring - Right Rear
  • * Customer Preferred Package 2TL
  • * Customer Preferred Package 28L
  • * Engine Discount
  • * Sold Vehicle
  • * Special Scheduling Condition VII
  • * Easy Order
  • * Status D1 To D1 Forward
  • * United States Region Group
  • * NAFTA Region
9 11/03/19
Pilotjeep
Pete
NYC
I hadn't considered that it could have both the wrorn diff and tires. I took a look at my diff cover, and it doesn't match any Dana identifier pics I can find online
Pilotjeep
Pete
NYC
That picture doesn't match. Mine has the plug towards the bottom of that flat, has angled rather than rounded upper and lower left corners, and has a different bolt pattern.
That pic is like other Dana 44 pics I see on identifier pages, which also don't match mine. For example, the one in the page that you posted matches the "Dana 44HD" on this page: https://www.randysworldwide.com/differential-identification-dana/ , but not the Dana 44.
Pilotjeep
Pete
NYC
Rudolph Hart
Cheshire UK
2018 JLUR GME Mojito!
Semi retired
OK, I see that - it's the D44. And hopefully LS per the build spec sheet.
The question remains, why do I have highway tires when all specs available when ordering say that it should have A/Ts
I’m a bit confused here, your posted build sheet lists...“255/70R18 All Season Tires” and the Bridgestone site says the tyres you have are “all season” so I’m not sure where the confusion is?
Buckster
Bradenton, FL
'19 billet silver JLUR '16 Grand Cherokee Overland
Power Generation
that’s a question you will have to take to your dealer. Honestly don’t understand why you haven’t at least called them.
All season tyres being different than all terrain tyres ...... seriously, that’s just a weird way to spell tires.
Buckster
Bradenton, FL
Power Generation
You got up at 5 am just to tell him that ?
Lol, my usual time for morning rituals....why you bustin on me homie??
Rudolph Hart
Cheshire UK
Semi retired
Yes I understand there’s a difference. The point I’m making is that his build sheet says ‘all season’ and that’s what he’s got regardless of how we spell tyres lol
Tri-City Jeep
