Putting Rubicon 4.10 gears in my Sport S?
UCnight
Alex
Kansas
2018 Wrangler JLU Sport S
I have a chance to get some 4.10 rubicon take offs. Was wondering what thoughts are on putting those in my Sport S to help with it's sluggish demeanor since moving to 33s.
I have the the Dana m186 on front and m220 on the rear. I do light offroading, and I am more looking to improve the on road capability of my jeep right now. It's a manual and 6th gear is useless, 5th gear can do highway speeds on flat ground only.
tkelly11
Tom
Chicago
www.wanderingobservations.com
Wrangler JL Sport S 2 Door
When you say sluggish, have you re-calibrated the transmission for the larger tires using like a flashcal or tazer? As when i swapped my tires out it was so sluggish but just updating the software to the correct tire size brought it back to pretty much exactly what it was before. Might save you some bother.
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
Whole axle swaps right? You cant just swap to rubicon gears they wont fit
UCnight
UCnight
Alex
Kansas
Yes, I have a procal, and I changed the tire size. It fixed my speedometer, but did not have any effect on the way it feels like it lost it's guts.
UCnight
UCnight
Alex
Kansas
That's what I thought as well, but apparently I can get a "carrier" for my current axles that will allow me to regear using the rubicon gears.
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
No, it will not work, the housing is too small on the front. By carrier they might mean axle assembly. It physically needs a d44 housing
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
You cant use the rubicon carrier either in the rear, spline count and axle shank are different lengths too
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
To be honest i dont understand why you would t just buy the correct gears and get it done, you have to have a shop install it anyways, and might as well have them do it all in one whack so they cant deny any warranty on it
UCnight
UCnight
Alex
Kansas
Good to know. Thanks for the info, I'll just look into a regular regearing at my local shop.
ChattVol
Tennessee
JLU 4 door
@Moto_21 knows his stuff...if you dont plan on wheelin your jeep much, makes sense to regear. If you think you may go to larger tires and start wheelin your jeep, now would be the ideal time to swap in takeoff rubi axles with brakes/lockers...thet can be found for $3500.
pubmeister
Connecticut
Jeep JLU Sport
I'm still pretty new to the Jeep world so could you explain further? I swapped over to 34" tires and have also experienced the sluggishness. Will programming the new tire size actually change the shift points? I had thought that it would only correct the speedo, which is not a big problem for me. If so, that is great as I don't really want to spend the money to regear.
tkelly11
Tom
Chicago
Yeah so that is correct, re-calibrating the transmission for the larger tires does adjust the shift points bringing the liveliness back to feel of it. I remember driving off after getting the 33's fitted and it felt so horribly slow, but then used a flashcal to update it and it went back to like 95% of what it felt like before. Annoying you have to spend $200 or so for the flashcal or tazer but well worth it and I understand that dealers will charge about $200 to do it for you.
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
I have a sport JLU v6, to run 35's for mainly highway riding and occaisonal trail riding (light) is regearing needed? I currently have 33s and it feels fine. Everything is stock.
At Risk Ute
Christian
milehightrails.com
‘94 YJ, ‘21 JLR, ‘22 JLUR XR, ‘23 392 XR
Retired Navy
Manny or auto? You notice the sluggishness more with the former.
