PSI for those running BFG KM3 37 x12.5 x 17 ?
peteinny
peter
ny
2020 wrangler
For those running BFG KM3'S in 37x12.5x17 what PSI are you running?
Carlton
Chicago
Jeeps lots of jeeps
I'm not running them but for that size 28-32 will be the proper range. Start at 32 and work down from there to find the sweet spot.
peteinny
peteinny
peter
ny
2020 wrangler
Thanks for the response. What are you basing your answer on?
Stickerhead
McKinney, Texas
2018 JLUR, 1997 TJ on 37’s, 2017 Powerstoke Tow Pig
I know you said KM3 but I run Ridge Grapplers, D load range 37’s at 28psi
WAOLIFE
Adrian & Josie
So Cal
2019 JLUM - 3.6L - Sky Touch & 2015 WK2O - 3.6L - IG: @wa0life
Fiddler of Parts
I cannot give you that answer, however I can supply you information about the KM3 35x12.5x17, I run them happily at 32.
WAOLIFE
Adrian & Josie
So Cal
Fiddler of Parts
Owning 50+ 37-40 inch tires. Over time you figure out what works best.
Unfortunately, or Fortunately . . . . . the KM3's characteristics are nothing like any prior MT's. They were conceived with a different design intent.
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
I am running the km3’s, not in a 37” but a 39”. I have worked my way down to 28/29 psi and the happy point.
peteinny
peteinny
peter
ny
2020 wrangler
Thanks for the info. I was thinking about starting at 32 and work from there
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
Correct pressure depends on the weight being supported so is different for different setups. Get some chalk and find the pressure that produces even wear.
DesertsJL
JLUR
I am currently running 30psi on my 37” KM3’s. It’s a hair too high. Going to drop to 28psi.
peteinny
peteinny
peter
ny
2020 wrangler
Tried them at 30 and ended up dropping them to 28. Seems like the right pressure.
Medsker
Jon
Herriman, Utah
2019 JLUR
I'm at 30 psi with mine. That's been working for me.
Means2212
Tyler
Georgia
2019 Ford Expedition, 2017 Ford Raptor, 2012 Ford Explorer, 2019 JLUR
I keep them around 28-30 seems to be about right so far. Their getting ready to hit 10,000 miles.
