- Jeff Allen
- Mar 5, 2019
- Azle, Texas
- 2018 JLU
https://www.pscmotorsports.com/vehicle-specific-products?cat=1699
18-19 Jeep JL BIG BORE XD Cylinder Assist Kit w/ Dana 30
The New Jeep JL is equipped with new computer controlled electro-hydraulic steering (EHPS), electronic stability control (ESC) electronic roll mitigation (ERM), and a weight saving aluminum housing steering gearbox. PSC has taken the Jeep JL steering system back to the drawing board and engineered our exclusive Big Bore XD-JL Steering Gearbox and a traditional belt-driven High Flow Mechanical Power Steering Pump Conversion, producing an essential upgrade to solve the original steering issues and efficiently handle the increased torque loads due to larger tire sizes and installing aftermarket axle assemblies.
Application:
2018 Jeep JL 2 Door/4 Door 3.6L Pentastar with OEM Dana 30 Axle
Features:
•Eliminates excessive on-center "play" at the steering wheel
•Eliminates electro-hydraulic pump overheating
•Increased Torque Output turns 37"- 44" tire sizes
•Improved turning capability when locking differentials are engaged
Includes:
•SG689R Big Bore XD-JL Cylinder Assist Steering Gear Box
•High Flow Mechanical Pump Conversion Kit
•Jeep JL Reservoir Kit
•Upgraded High Pressure Hose Assembly
•Upgraded Return Line Kit
•Fluid Cooler Kit
•SC2222 Steering Assist Cylinder Kit
•Tie Rod Clamp (available in 38MM or 40MM sizes)
•SWEPCO 715 Power Steering Fluid
18-19 Jeep JL BIG BORE XD Cylinder Assist Kit w/ Dana 44
The New Jeep JL is equipped with new computer controlled electro-hydraulic steering (EHPS), electronic stability control (ESC) electronic roll mitigation (ERM), and weight saving aluminum housing steering gearbox, PSC has taken the Jeep JL steering system back to the drawing board and engineered our exclusive Big Bore XD-JL Cylinder Assist Steering Gearbox and a traditional belt-driven High Flow Mechanical Power Steering Pump Conversion, producing an essential upgrade to solve the original steering issues and efficiently handle the increased torque loads on vehicles equipped with any combination of the following:
37 Inch and Larger Tire Sizes
Upgraded Aftermarket Axles including Dynatrac, Teraflex, and Currie.
Differential Lockers
Application:
2018-2019 Jeep JL 2 Door/4 Door 3.6L Pentastar with Factory Rubicon Axle and Factory Tierod.
Features:
Relieves stress on steering gearbox and frame mounts
Steering Assist Cylinder acts as a dynamic steering stabilizer
100 percent bolt on, no welding required (with factory tie rod config)
Includes:
Fluid Cooler Kit
SC2201K Steering Assist Cylinder Kit
Tie Rod Clamp (available in 1 1/4", 1 3/8", 1 1/2", 1 5/8", and 1 3/4" sizes)
18-19 Jeep JL BIG BORE XD Overlander Steering Kit
Application:
Features:
•Increased Torque Output turns 35"-37" tire sizes
Includes:
•SG689 Big Bore XD-JL Steering Gear Box
•Fluid Cooler Kit
18-19 Jeep JL Power Steering Pump Conversion Kit
18-19 Jeep JL BIG BORE XD Cylinder Assist Ready Kit
Application:
Features:
Includes:
•Fluid Cooler Kit
Application:
Features:
Includes:
Fluid Cooler Kit
Application:
Features:
Includes:
•Fluid Cooler Kit
