Proximity door locks retrofit install (instructions, parts, links) on JL Wrangler
jlgunner2
Karyl
MD
2018 JLR
So I completed the installation on the driver side door tonight. And in an abundance of caution, decided to test the windows and power locks before moving onto the passenger door and tailgate.
The windows work just fine, but now power lock and mirrors are OUT across the entire jeep! Key fob still works, though, for both lock and unlock.
Is this normal when you only have one door set up for proximity, but not the others?
FYI -- I did try reseating all cables and tried swapping out handles and caps (didn't swap out wire harness yet).
Thanks for any advice!
That’s not normal. I had the driver and tailgate installed while waiting for passenger harness to come in.
Gregj
Greg
West Texas
JLU Rubicon, JLU Sport, JTuRD
You have bent pins in the connector for the door, it is very easy to do. Disconnect the door and look in the body side of the connector and one or more pins will be out of alignment, carefully bend them back in line with the rest. I had the same issue after I put the doors back on one time.
FCA could use a more robust connector for something that is designed to removed and replaced often.
Gregj
GatorMBA
2020 Sahara JLU
Gregj
This is EXACTLY what it was. I'm so relieved that it wasn't something related to my installation. Thank you!
Grateful1
Grateful
Guntersville, AL
2018 JLU Sahara 1998 TJ Sport 2011 Extreme Camper
HR Manager
Got to like it when you ca rebound from a boo boo easily like that. Want to come over and help me. 😂
GatorMBA
2020 Sahara JLU
If you were a little closer than Alabama -- or if I lived in the Panhandle closer to you -- I'd come help ya out for a sandwich. Honestly, this was kind of a fun little DIY project.
P.S. @Grateful... I cannot stress enough that when you do it, do not skip/miss the "tuck the extra pigtail behind the white window guard" step. I did this at first, rolled my window down, and *SNAP.* I was very lucky and the window just yanked the pigtail connector out instead of ripping wires out.
Grateful1
Grateful
Guntersville, AL
HR Manager
Thanks for the heads up. The (before we dated) wife bought the ‘98 TJ Sport off the lot two years after she graduated from Auburn on Memorial Day weekend. So we bought off the lot in ‘18. It didn’t have any upgrades except a Dana44 rear for the Sahara. So I am adding all the Mopar upgrades I can. The proximity locks I hope will be a fun upgrade. After my next deployment in September I will add leather with heated seats & a lift.
Edit. Off the lot in ‘18 on Memorial Day weekend.
calvinf1
Calvin
Northeast
2020 JLU North Edition
100% agree about tucking the pig tail behind the track. This took awhile to figure out the most proper way to route the wire. Also it is good to test the window right away before bolting things back together.
This was one of the more painless DIY project.... thanks to JSCAN making it possible.
Now that I have this feature, I can't imagine not having this in future cars.
Purplehayes
Nj
2021 Willys
I have a 2021 JLU Willys and I bought all the parts to do both front doors and the rear door. My Jeep had the wires in the dash harness so I added the door harnesses and handles with the new pieces next to them. Used the Tazer mini to activate it and only my rear door handle works. Has anyone had this happen? I checked the dash harness for bent pins as someone else recommended but every thing looks good. Any help would be great. Thanks.
david63
Overland Park, KS
2020 JLU Sahara, 2018 & 2015 2 door JK Sport
The harness and cap both seem good not sure if I can test the handle but that seems to be the part that is the most complex. Figured what the heck ordered another set of parts and will see if that helps otherwise I’ll have a tailgate set for sale at some point.
For those following my tale of frustration I just got a new set of parts for the tailgate, I was able to quickly try the new cap & handle, and no luck, key fob flashes but no lock or unlock. The last thing is the new harness which I will try later, not feeling real positive about that helping but we will see. If this does not work then I'll have a nice new set for the tailgate for sale.
ZeroTrev
Trevor
colorado
2018 JL
I found it! Thank you
david63
Overland Park, KS
After testing all the new parts I end up with the same result so it seems the parts are fine there is something else going on, any thoughts would be appreciated. That being said I have the harness, cap, and handle for the tailgate will sell for $120 shipped in the US(I paid $125 + Shipping). Just let me know if you are interested
calvinf1
Calvin
Northeast
Sorry to hear about your continued struggle on this. What's next?
HungryHound
TN & FL
1975 CJ-5, 1983 CJ-5, 1998 TJ, 2021 JLURe
As stated in previous thread you want to make sure you already have the antennas needed. Sahara and Rubicon are supposed to already have them if you have keyless entry w/ push to start.
This is what I did along with the videos and resources I used.
Step 1 - swap handles
(Parts Needed: Torx T20)
Follow this video:
rear swing gate has a grommet that needs to be removed to access the T20 screw holding the cap.
Step 2 - remove door panels.
(Tools needed: Torx T20, Torx T30 & plastic pry tool)
PDF
http://www.myjlproject.com/blog/wp-content/uploads/2018/10/Door-Trim-Panel-Removal.pdf
Follow this video to remove the panel
Step 3 - remove inner door card
(Tools needed: 10mm socket)
PDF
http://www.myjlproject.com/blog/wp-content/uploads/2018/10/Inner-Door-Plate-Removal.pdf
Remove 9 bolts around perimeter of the plate.
(Pic of all bolts and wires removed)
Roll the window down till you see the bolts holding the window. Remove bolts holding window and tape window up to keep it out of the way.
Once you have the window up you need to carefully pull the inner card back enough to get to the wire to the door lock and handle. This is the hardest part, you have to lift up slightly to get the bottom out first. You then have to pull down and twist just enough to clear the power window track and actuator.
(Tried to get a pic of the track you need to maneuver out)
Once you have the card pulled back enough remove and replace the door harness. This part is pretty self explanatory. Just make sure when you add the handle pigtail it is out of the way of the window path.
Step 4 - put everything back together
Step 5 - rear swing gate jumper
(Tools needed: Plastic pry tool)
Using a pry tool firmly pull the plastic panel off on the rear swing gate
(Pics borrowed from fellow members)
Step 6 - replace power lock harness with new jumper
Step 7 - put plastic panel back on
Step 8 - go to dealer and have them add sales code GXD and program vehicle
Parts List:
DOOR HARNESS
LF door
P/N 68325454AE (w/o BSM) - https://www.moparoneonline.com/oem-parts/mopar-front-door-wiring-68325454ae
P/N 68299333AE (w/ BSM) - https://www.moparoneonline.com/oem-parts/mopar-front-door-wiring-68299333ae
RF door
P/N 68325461AE (w/o BSM) - https://www.moparoneonline.com/oem-parts/mopar-front-door-wiring-68325461ae
P/N 68299332AE (w/ BSM) - https://www.moparoneonline.com/oem-parts/mopar-front-door-wiring-68299332ae
Rear Gate Jumper
P/N 68351167AA - https://www.moparoneonline.com/oem-parts/mopar-jumper-wiring-68351167aa
HANDLES
Front doors
P/N 68307269AC - https://www.moparoneonline.com/oem-parts/mopar-exterior-door-handle-right-68307269ac
rear swing gate
P/N 68309825AC - https://www.moparoneonline.com/oem-parts/mopar-exterior-door-handle-68309825ac
CAPS
Front door caps
P/N 68307272AD - https://www.moparoneonline.com/oem-parts/mopar-door-handle-cap-right-68307272ad
Rear swing gate
P/N 68309830AC - https://www.moparoneonline.com/oem-parts/mopar-door-handle-cap-68309830ac
Great post, but you really should have put more plates on the bench press bar for the swing gate photo.
