Proximity door locks retrofit install (instructions, parts, links) on JL Wrangler
Bigdogfan63
2018 Wrangler JL
Was thinking of this option at $99 until I saw they raised the price to $149....for 4 wires? Better come with dinner and a move for that kinda cash....I'll build my own.
The jacket o the wire will not fit in the connector
heykoolaid3
Jake
Phoenix
2018 JLUR Firecracker Red
So I only had all of the parts today to do just the swing gate. All parts installed and it worked as soon as I plugged it in. So at least I can put my groceries in the back without taking my keys out. :LOL:
You didn't have to update the computer to recognize???
Bigdogfan63
2018 Wrangler JL
Does anyone know the difference between the drivers door and passenger door harnesses?
Gregj
Greg
West Texas
JT Overland North Edition, JlU Rubicon, JLU Sport, upgrades in progress!
ZeroTrev
Trevor
colorado
2018 JL
Mine shipped today! Hopefully next weekend I'll be able to install it.
JK’sJL
Jon
Alabama
2021 Sahara
I posted a thread asking about this, but figured it may get more traction here.
I ordered the proximity kit and installed it(2021 Sahara) with the tazer mini. Whe I got done with the install everybting worked perfect, excepts the proximity sensor on the passenger side stays illuminated. I did the trouble shooting the company I purchased from asked and nothing worked. I plugged in my factory harness and clicked on the proximity harness and the light cut off, I unplugged that one connector and the one at the footwell and plugged the new harness in and the light came on within 3 seconds. I let them know this and they shipped out a brand new harness. I installed it tonight and it does the same thing.
I can cut that off on the stereo, so it’s not a huge deal as I always look anyway, but curious if anyone has run into this issue or what the fox could be?
the company asked me to disable the tazer and reinstall, but onceI showed them video of using thefactory harness and it cutting off they figured it was the harness. Could it be a flash is needed?
Also, no pins are bent.
JK’sJL
Jon
Alabama
2021 Sahara
Here is a picture of the connector for the mirror. The one on the left is my factory harness, the right is the one that added the wires for the proximity door handles. In addition to the two extra wires, this white with a brown strip on the top row is also extra(not sure what it is or if it could be the issue or not).
Gregj
Greg
West Texas
The Proximity lock wires do not go through that connector, the Power Mirrors and Blind Spot Monitoring wires are in there and in the Export model the Mirror Repeaters are there too. Have them recheck the part number they are sending you.
Gregj
Gregj
Greg
West Texas
Post the part number of the original harness and the number of the one they are sending you.
Gregj
JK’sJL
Jon
Alabama
2021 Sahara
Update to my issue. The light and everything always pointed to the passenger side. I was reading over at the gladiator forum and someone mentioned the same issue when taking doors off. I checked the driver side connection and straightened all pins and now the light has gone away. So even though everything pointed at the passenger side, the driver side connection fixed it. I hope this helps others out.
LeodaJeep
Leo
SoCal below Idyllwild mountains S.W. side.
2019 Jeep Wrangler JL Rubican
Self Sufficient
As stated in previous thread you want to make sure you already have the antennas needed. Sahara and Rubicon are supposed to already have them if you have keyless entry w/ push to start.
This is what I did along with the videos and resources I used.
Step 1 - swap handles
(Parts Needed: Torx T20)
Follow this video:
rear swing gate has a grommet that needs to be removed to access the T20 screw holding the cap.
Step 2 - remove door panels.
(Tools needed: Torx T20, Torx T30 & plastic pry tool)
PDF
http://www.myjlproject.com/blog/wp-content/uploads/2018/10/Door-Trim-Panel-Removal.pdf
Follow this video to remove the panel
Step 3 - remove inner door card
(Tools needed: 10mm socket)
PDF
http://www.myjlproject.com/blog/wp-content/uploads/2018/10/Inner-Door-Plate-Removal.pdf
Remove 9 bolts around perimeter of the plate.
(Pic of all bolts and wires removed)
Roll the window down till you see the bolts holding the window. Remove bolts holding window and tape window up to keep it out of the way.
Once you have the window up you need to carefully pull the inner card back enough to get to the wire to the door lock and handle. This is the hardest part, you have to lift up slightly to get the bottom out first. You then have to pull down and twist just enough to clear the power window track and actuator.
(Tried to get a pic of the track you need to maneuver out)
Once you have the card pulled back enough remove and replace the door harness. This part is pretty self explanatory. Just make sure when you add the handle pigtail it is out of the way of the window path.
Step 4 - put everything back together
Step 5 - rear swing gate jumper
(Tools needed: Plastic pry tool)
Using a pry tool firmly pull the plastic panel off on the rear swing gate
(Pics borrowed from fellow members)
Step 6 - replace power lock harness with new jumper
Step 7 - put plastic panel back on
Step 8 - go to dealer and have them add sales code GXD and program vehicle
Parts List:
DOOR HARNESS
LF door
P/N 68325454AE (w/o BSM) - https://www.moparoneonline.com/oem-parts/mopar-front-door-wiring-68325454ae
P/N 68299333AE (w/ BSM) - https://www.moparoneonline.com/oem-parts/mopar-front-door-wiring-68299333ae
RF door
P/N 68325461AE (w/o BSM) - https://www.moparoneonline.com/oem-parts/mopar-front-door-wiring-68325461ae
P/N 68299332AE (w/ BSM) - https://www.moparoneonline.com/oem-parts/mopar-front-door-wiring-68299332ae
Rear Gate Jumper
P/N 68351167AA - https://www.moparoneonline.com/oem-parts/mopar-jumper-wiring-68351167aa
HANDLES
Front doors
P/N 68307269AC - https://www.moparoneonline.com/oem-parts/mopar-exterior-door-handle-right-68307269ac
rear swing gate
P/N 68309825AC - https://www.moparoneonline.com/oem-parts/mopar-exterior-door-handle-68309825ac
CAPS
Front door caps
P/N 68307272AD - https://www.moparoneonline.com/oem-parts/mopar-door-handle-cap-right-68307272ad
Rear swing gate
P/N 68309830AC - https://www.moparoneonline.com/oem-parts/mopar-door-handle-cap-68309830ac
LeodaJeep
Leo
Self Sufficient
Just received my kit. Compared the part numbers to the list posted and all is correct. Crazy thing though is that the end caps have a 1.5" protruding end and the handle ends are solid. How do you put a protruding end into a solid piece?
Gregj
Greg
West Texas
All will become clear when you start the install. Follow the video.
Gregj
Deke
2019 JLU
The end caps fit like this. You put the handle in the door and then the end cap slips in next to the handle, not inside or attached to it.
Northridge4x4
