BillyHW
Hypothetically speaking,
let's say you have a spare tire that was never used because you never included it in your rotation, or maybe you even have a spare tire that was nominally the same tire size code, but is a different brand/make/model of tire,
and let's say that your regular 4 tires are pretty worn down,
and then let's say you get a flat tire.
What would be the proper procedure for putting on the spare?
In this case your spare tire might be quite a bit different size than your remaining 3 good tires.
Can someone confirm that this would be the correct procedure and would be safe without damaging anything:
1. If the flat is on a rear tire, move a good front tire to the back and mount the spare tire to the front.
2. Drive home only in 2WD (=RWD on the Jeep). Do not engage 4WD until you get equally sized tires on all four spots again.
