PREVIEW: JL Patriot Series Rear Bumper With Tire Carrier
ROCK HARD 4X4
Peak Sponsor (Level 2)
United States
Jeeps
The strongest and most premium Patriot Series rear bumper with tire carrier we've ever built is just about ready! You'll see it on the website very soon.
RH-90301 - Steel Rear with Tire Carrier $1,399.95
RH-90300 - Steer Rear, non Tire Carrier $799.95
RH-90340 - Aluminum Rear, non Tire Carrier $899.95
We believe Jeep armor upgrades can be both extreme duty and retain factory features. We aren't first to market with a JL rear bumper and tire carrier, but this couldn't be rushed. Our Patriot Series JL rear bumper with tire carrier hosts all our standard features, plus retains all the factory options available for the current Wrangler.
What took us so long? We wanted this bumper to be 1/4" thick like all our other rear bumpers. Problem was the optional sensors for the JL rear. There was not a grommet on the market for that size sensor to fit in 1/4" thick material. So - we made it!
Optional Upgrades:
- Tank Mounts (same ones currently available from Rock Hard 4x4)
- Cargo Basket (same one currently available from Rock Hard 4x4)
Features:
- 1/4" thick plate steel (steel tire carrier version)
- Adjustable tire mount
- Reverse camera compatible
- Sensor compatible
- License plate/light compatible
- 3rd brake light compatible
- Jack-mount included
- Antenna mount included
- 1" thick recovery tabs included
- Tow electrical harness compatible
- Powder coat
- Bolt-on
- 100% Made in the USA
Options Coming Soon:
- Muffler Skid Plate
45017789_1868530403196545_6155309784439455744_o.jpg?_nc_cat=101&_nc_ht=scontent-lax3-1.jpg
45002923_1868530439863208_4215641165598294016_o.jpg?_nc_cat=108&_nc_ht=scontent-lax3-1.jpg
45135299_1868530363196549_6188627039755436032_o.jpg?_nc_cat=106&_nc_ht=scontent-lax3-2.jpg
45040046_1868530463196539_9195978898649645056_o.jpg?_nc_cat=103&_nc_ht=scontent-lax3-1.jpg
45007920_1868530479863204_7962071748407459840_o.jpg?_nc_cat=108&_nc_ht=scontent-lax3-1.jpg
mikej
SF Bay, California
Thank you for being thoughtful about the proximity sensors. I've been disappointed by some of the spare tire mount bumpers that have blown it with the prox sensors.
Shenanigans
NorCal
JLU Rubi
That setup looks great! I really like how the bumper wraps around the body but doesnt blend into the flares. Im going to run tube fenders on mine and this would be perfect. Job well done!
Chocolate Thunder
Jeremy
Will the rear bumper accommodate a 35” spare tire on the OEM wheel mounted in the stock location? Can the RockHard tire carrier be ordered separately and mounted onto the steel bumper later if thevbumoer is originally ordered without it?
ROCK HARD 4X4
ROCK HARD 4X4
United States
Jeeps
Just like a 35" won't fit on some factor JL rear bumper versions, a 35" tire will require a relocation bracket. We offer a heavy duty adjustable mount that will allow a 35" to clear either the factory bumper or ours. We move your receiver up for clearance since they so commonly get wheelers hung up.
Adjustable Mount:
https://www.rockhard4x4.com/product_p/rh-90347.htm
If you order our non tire carrier bumper you won't be able to add the carrier post later.
UKCATS
DFW
2020 JLUR Recon/2020 Mazda3 Hatchback
I play piano in a whorehouse
Can you get the aluminum bumper without the holes for backup sensors, or do you provide plugs? Pics of non tire carrier version? Also, will the non tire carrier version work with factory Rubicon spare on factory tire carrier?
ROCK HARD 4X4
ROCK HARD 4X4
United States
Jeeps
All bumpers will have sensor holes, but for wheelers without sensors we do include plugs to close the holes.
The bumper will work with the factory spare mount. To run a 35" or larger spare you'll need our adapter mount found here:
ROCK HARD 4X4
ROCK HARD 4X4
United States
Jeeps
I'm also curious if there will be a version available without the tire carrier.
Yes, non tire carrier versions in both 1/4" thick steel and 1/4" thick aluminum.
Photo below shows our body mounted tire carrier RH-90350, sold separately.
UKCATS
DFW
Do you have a pic of the bumper with the factory 33” spare on the stock spare mount? I’m not seeing how it will fit since the bumper doesn’t have a cutout.
ROCK HARD 4X4
ROCK HARD 4X4
United States
Jeeps
I don't have a photo of our non tire carrier rear with a 33" tire yet, we'll begin shooting our install videos soon so that'll help. 33" is close but does fit with the factory mount. Another option is our adjustable mount for under $110. Plus it gives you a CB antenna mount built in.
UKCATS
DFW
Thank you for responding. I have used your skid plates and rock sliders, and have been very happy with your products. Looking forward to seeing additional photos.
ROCK HARD 4X4
ROCK HARD 4X4
United States
Jeeps
JL Rear Bumpers are coming!
This run of rears just left media blasting headed to powder coating.
46083207_1887481954634723_7110092241384767488_n.jpg?_nc_cat=105&_nc_ht=scontent-lax3-1.jpg
ExitLeft
Wes
Philly ‘burbs
2003 Jeep Wrangler TJ
Bumpers look fantastic. Love the recessed license plate, integrated hitch, and mounting for the hitch wiring. I've been waiting for this bumper.
Is there any chance you'll offer an option to NOT have the holes drilled for the sensors? I don't really want to put plugs in if that will be an option.
Your skid plates and front & rear bumpers will definitely be on my 2019 when it arrives.
Thanks
