Josh/AWE
Peak Sponsor (Level 2)
Philadelphia
JL & JT
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 22722
It's an AWE thing. Presenting the Best Sounding Exhausts on the Planet™ for the JK/JKU Wrangler:
  • Loop replacement pipes, mid pipes, axle-backs, and crawler configurations -- modular options for all
  • Handcrafted from 3” and 2.5” U.S.-made CNC mandrel-bent .065” wall T304L stainless steel
  • Proudly engineered, designed, and manufactured in-house, in the USA
  • Available as crawler-engineered Trail Edition and road trip-friendly Tread Edition
  • Tread Edition features AWE’s proprietary, patented drone-canceling solution, 180 Technology® and bespoke dual 4.5” slash-cut tips
  • Trail Edition provides best-in-class clearance on even the most aggressive departure angles
  • Resonated and Non-Resonated Mid Pipes available separately
  • Dyno-verified max gains of 5 hp and 10 ft-lbs of torque at the wheels
  • Direct bolt-on for factory-like simplicity, no cutting required
  • Less is more: clean, straight-through design maximizes performance
  • Dual 4.5” slash-cut, double-walled tips available in chrome silver or diamond black (Tread Edition)
  • Dyno-engineered, trail-proven
  • Perfect fitment, guaranteed
  • AWE No CEL Guarantee
  • Lifetime warranty on exhaust
Tread Edition:
The Jeep Wrangler exhaust that will sound good no matter where you are on the planet.
Handcrafted from US-made 3” and 2.5” T304L stainless steel, the Tread Edition is a straight-through axle-back configuration for drivers looking for rugged performance and a drone-free, signature exhaust note without sacrificing daily-drivability.
The Tread Edition features AWE’s patented, drone-canceling 180 Technology®, which provides the JL/JLU with a sophisticated, full-bodied soundtrack completely controllable via the throttle. With increased throttle, the Wrangler roars with aggression, but at highway speeds, the cabin is free of any drone, and volume is similar to stock.
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-33001_1_1
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-32001_10_1
Perfect tone, compliments of AWE 180 Technology®.
As exhaust gases exit the 2.0T/3.6L engine and flow into an AWE 180 Technology® equipped resonator, they pass through strategically located ports, and into reflection chambers. Sound waves, carried by these exhaust gasses, bounce off the walls of the reflection chambers. By controlling the size and location of the ports and the chambers, we also control when the sound waves exit the chambers. The specific timing of when the reflected sound waves rejoin the main exhaust flow creates a one-hundred-and-eighty-degree out-of-phase sound wave that cancels out problematic frequencies.
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-33001_7
Mid Pipes:
Options and customization are important to us, just like it is to you.
We engineered bolt-on mid pipes to pair with your Tread Edition Axle-back for additional sound tuning and performance. Replacing the factory mid section is a robust 3” stainless steel mid pipe available as resonated or non-resonated.
For drivers looking to really uncork all of their Wrangler’s aggression should consider the non-resonated mid pipe. For those looking to up the volume while keeping it sophisticated, go resonated. Regardless of which mid pipe is chosen, drivers can look forward to keeping the cabin drone free, thanks to the 180 Technology® featured in the Tread Edition.
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3020-11001_1
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-11001_1
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-32001_3015-11003_3
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-32001_3015-11003_2
Tip Options:
When it comes to bringing up the rear, drivers have a couple of options. Say goodbye to the ugly suitcase muffler and dangling tail pipe, and hello to dual 4.5” double-walled, slash-cut tips in either chrome silver or diamond black.
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] awe_jl_tips
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-32001_12_1
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-32001_13
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-33001_12
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-33001_13
Trail Edition:
Crawlers and overlanders: unite. The AWE Trail Edition is not only engineered to provide the best sounding exhaust note to ever be heard on the trail, it also provides maximum ground clearance while trekking rough terrain.
The Trail Edition is a 3” straight-through catback configuration featuring a bespoke mid pipe resonator, and ends right after the rear axle, tucked up next to the spare wheel well out of the way of danger. You’re left with a rugged, USA-made exhaust that provides a bespoke, drone-free soundtrack and peace of mind unlike anything else on the market.
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-21003_1
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-21003_6_1
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-21003_5
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-21003_8
Loop Replacement Pipe:
Clearance matters, and the AWE Loop Replacement Pipe delivers. Ditch the loop connection and replace it with a single, smooth, swooping bend of 2.25” T304L stainless steel that bridges the gap between your factory catalyst and exhaust seamlessly. No cutting required.
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3220_11001_1
What’s in the box?
Complete Tread or Trail Edition Exhaust, tips (if applicable) in the desired finish, and all necessary hardware for installation.
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-33001_6
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] 3015-21003_3
Data:
Jeep Wrangler JL Presenting the AWE Exhaust Suite for the JL/JLU. Available now. [Videos, Sound Clips, Dyno] AWE_Jeep_36L_Wheel_Dyno
Chocolate Thunder
Jeremy
So there’s Tread edition sound clips for both resonated and non resonated mid pipes, but no sound clip of what the trail edition sounds like. How does the trail edition sound level compare to the tread edition?
Josh/AWE
Josh/AWE
Philadelphia
JL & JT
Thanks for askin'!
The Resonated Tread Edition would be the reference for the Trail Edition. The difference lies in the axleaback, with our patented straight-through 180 Technology® resonators that kill drone prone frequencies, exiting the rear. That aside, they're similar to a straight piece of stainless. No packing material is used in our technology. Tread Edition is very sophisticated on the highway, whereas the Trail may be a bit more present to some (others might not notice).
Trail was engineered to stay clear of danger (the Earth) when trekking terrain -- typically where drone at highway speeds is not a concern 😎 .
All of the sounds heard in the launch video at the top of the thread are courtesy of the respective Trail Editions for the Wrangler (and Gladiator).
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
Mechanic
The majority of the folks who are going to change their stock exhaust on a Jeep, do so in order to get rid of the poor clearance from the stock muffler. So the trail version is likely to be a more popular option. But only if we can directly compare the sound. If all the clips are with dual outlets, which will sound different, then I can't judge whether this sounds better than a competitors product.
ChromeToaster
Arizona
21 JL Rubicon, 03 Honda XR650L
agree get us a trail high clearance audio option and ill look into it.
stylett9
Idaho
Jeep
Would love to hear the 2.0T and dyno's as well. I'm cautiously optimistic maybe there's even more performance gain which would be a really nice plus.
And as others have mentioned, Trail edition. Or whichever the high tuck is.
Josh/AWE
Josh/AWE
Philadelphia
JL & JT
@Dave/AWE and I be capturing footage of the 2.0T as soon as the weather at the strip allows it!
JeepinJason33
Denver
2021 JLUR, 2021 GCL, 1997 TJ, 1983 Chief FSJ
"Trail was engineered to stay clear of danger (the Earth) when trekking terrain -- typically where drone at highway speeds is not a concern 😎 ."
So are you saying that the trail edition has drone? I am looking for something without the rear muffler and tailpipe without drone...
I certainly like the sound of the dual exhaust, but any kind of light wheeling will smash those pipes into the bumper.
CodyA
Cody
2020 Jeep Wrangler Unlimited Rubicon
Agreed with the trail version clearance video. Those dual exhaust tips are begging to be flattened out on some rocks.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Wandering Vaquero
Bespoke...
Anyway, sounds good. I like that there’s no crackle.
ErAcEr
Matthew (Mateo)
Indianapolis, IN
2018 JLU, 2021 ZH2 , 2018 Z900, 2013 Vulcan 1700
Engineer/Technician
Sounds and looks good, but that driving 5-70mph looks like they need the steering TSB :LOL:
RubiRob
Rob
Hampshire, IL
www.instagram.com
Mojave
Just looking at the photos it doesn’t seem like it’s going to be very quiet. Hopefully I’m wrong.
Josh/AWE
Josh/AWE
Philadelphia
JL & JT
I can see the confusion. Apologies, allow me to elaborate.
The Tread Edition is so finely tuned that on the highway, one could forget there's an aftermarket configuration equipped. That's due to the 180 Technology® and its refinement capabilities.
Trail, on the other hand, is more telling there's a straight-through 3" configuration tucked up under your carriage. It's more aggressive and not as refined within the cabin. It doesn't drone, but it's aggressive.
Regarding tailpipes on the Tread Edition: they can always be easily removed when going wheeling via the two clamps. This was by design 👍
