gkrash
- Gary
- Mar 18, 2019
- Harrisburg, PA
- 2019 JLU Sahara
Hey All,
So I'm a new Wrangler owner, so I'm not entirely sure what I should be going to the dealer with and what not to..
The issue I've got is this, I've got a tan premium soft top, and the rear window on the drivers side is *loose* in the back. It still stays in fine when I have the rear window in, but with it out, it doesn't take much effort at all to pop it out of position, especially compared to the passenger side, which takes a solid whack to get it out.
I took about 30 measurements just to be sure, but it appears to me in a variety of ways that the roof is actually about 1/4 to 1/2" higher on the drivers side than the passenger side. I am 99% positive this is what is causing my issue - what I don't know is how to fix it, or if I even should. I found some adjustment screws and attempted to adjust the length of the top thinking it would bring it down, but that didn't seem to do it. The rear support arm is actually contacting the hub the way it should be too, which is confusing the life out of me. The only thing I can think of is that it's very slightly bent, but I have absolutely no idea how that would have happened, nor what I should do about it.
I suppose the question is, do we think the dealer will do anything for me with this? or am I own my own.. I suppose it's possible something happened during the installation, (I got the dual top, so I had to do the initial install) but I honestly can't remember anything that would have caused something to bend unless it's made of lead...
@JeepCares thoughts?
(I originally posted this in the wrong spot, going to delete the old one immediately..)
-- G
-- G
