Powered accessories
J_Winslow
Jeremy
Virgina
2022 Rubicon Xtreme Recon
I have 4 aux switched and so far only used one for my OBA.
What do you guys run??? I am no light bar fan and I cannot really think of other things that need switches. Thought about an air horn but that would get me in trouble 😈😈
Old Dogger
Bill
Cave Creek Arizona
2013 JKR, 2018 JLR
Retired High level Management.
How about windshield pillar mount lights?
Ironjaw
MN
2021 Jeep Wrangler
1 for my OBA and 1 for my GMRS. Next will be the light bar.
rkwfxd
Rich
Whittier
2021 JLR, 2020 Tahoe 4x4, 2006 Tundra, 1990 964
Unemployed
OBA
Winch Power Solenoid
A-Pillar Lights
Rear Chase Lights
Rock Lights
Siren
Horn
Ham or GMRS or CB
Yossi
Yossi
Israel
Rubicon
I'm using
1 OBA
2 Fridge
3 water pump
J_Winslow
J_Winslow
Jeremy
Virgina
OBA
A-Pillar Lights
Rear Chase Lights
Rock Lights
Siren
Horn
Ham or GMRS or CB
What's with the winch power??? On my old jeep the winch was just wired to the batter and you simply plugged in the controls.
Also I have thought about rock lights. I have an LED light setup that works with a Bluetooth controller I was going to use in my C8 but didnt.
rkwfxd
Rich
Whittier
Unemployed
No power to my winch so no one can mess with it but more important, in a front end accident It helps prevent a short / fire.
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
Aux3 is the ignition source to the VOSwitch.
Aux4 provides power to my dash USB power ports and cabin lights.
VOSwitch has winch power solenoid, bumper lights, pillar lights, and rock lights.
double J
Johnny
Glen Allen Va
2022 rubicon Xtreme
I had the same problem. Found a novelty horn my father gave me several years ago.
Opus
Midwest US
www.jlwranglerforums.com
2023 Sport S (on order), 2021 Compass
On a related note... can anyone recommend a tutorial or YT video for how to wire an accessory to an aux switch?
Rhinebeck01
2018 2dr. Rubi
@Opus
While some YT videos are very good and offer correct, helpful info, do be very very careful following info/direction heard and seen on them.
Always confirm/verify the info you gain from the YT video. Why, because some YT videos can get you into a mess so to speak... thanks to misinformation, etc. in them.
Read this whole thread... As you are reading, or after reading ask ?.
You will find all the info you need in that thread and if not ask your ? as there are many here that can give you guidance and other's here that can confirm or reject info you receive.
https://www.jlwranglerforums.com/fo...switches-configuration-installation-diy.1477/
bonniejf
Bonnie
Tuscaloosa, AL
2019 Jeep JL
  1. 7" LEDs on the front bumper
  2. 20" amber LED bar under bumper
  3. LEDs in rear bumper for setting up camp
  4. Dometic fridge
Could you tell me how you wired your dometic fridge to the aux switch? I bought the dometic hard wire kit but the 10 ga wire with the kit is bigger than the aux switch wiring (14ga?) and I'm wondering if that is a problem. I want the dometic fridge to be hooked up to my dometic plb40 and I want that only hooked up to a switched connection since the plb40 doesn't have battery protection (and I have a manual so passing thru firewall more complicated). Thanks! I can only find a couple youtube videos that talk about the wire size difference and there's always someone in the comments saying not a smart idea.
Ratbert
COS region, CO
AEV JL370 JLURD , AMG GLC43
Software Engineer
Mine is the Dometic DC30, so there's a good chance that it draws less power than yours. I just ran it to aux switch 4 since it draws so little juice. I didn't, however, do the full verification that I wasn't going to overload it. No issues...so far.
Note that the aux switches seem to have battery protection. I say that after accidentally leaving the fridge on for a few days and seeing it turned off when getting in the next time.
Terpsmandan
Penn Yan
Winch solenoid on Aux 3.
Capital CDJR
