Shots
Yes they exist.I've seen people posting screenshots of averaging mpgs in the 24's, 25's and as high as 28mpg with ranges of 400-500+ ranges.
.........do these number really exist or are people somehow fudging there claims?
This was from a road trip to northern MI from June of this year. I got 26.7 mpg. I hand calculated when I filled a few hours later, and this was pretty close to what I calculated.
For details, I have a 4 door, Sahara, automatic with a 2" lift and hard top. I've got 34" KM2's and V6 burning 89 octane gasoline. I set the cruise at 65 mph and stay in the right lane so all the speeder can pass if they want to, so I rarely have to speed up or slow down. Maintaining speed is the key to efficiency because it keeps the rpm's down..
As you can see this is 168 miles, and 2 hours 47 minutes into the trip. If you do the math it works out to 60.6 mph, which accounts for the time spent on surface streets, but it was mostly interstate. This portion of the trip was pretty flat as I was heading southbound toward Ohio. I snapped the photo when I stopped at Cabela's because I was amazed at how well it was doing on fuel.
If I can get nearly 27 with my setup, I absolutely believe someone can get to the 30 mpg range with no lift, on stock tires. To be fair, they're probably not doing it at 70+ mph, but with the right conditions, I can see it happening.No way!! Theres more to this....that's impossible.
I'm not stupid by a long shot.
no way 30 average no way beat it
Someone already mentioned it, but the issue is that FCA is testing in a lab with specific guidelines on HOW the test must be done. The idea is to establish an AVERAGE mpg consumers can expect. It's reasonable that some people get better than reported efficiency because some people are getting worse than reported. As expected, that make the average land right round the reported numbers.But how? How did you get 28mpg? How.
My argument is, if someone can actually achieve 28mpg avg, why won’t FCA market the JLs as such, what are you doing that nobody else are to get those numbers? Is this repeatable?
I’m really curious to see the math behind it.
The EPA guidelines ensure that all manufacturers are testing the same way, so the consumer has a number that can be accurately compared.
Exactly my point. Thank you.Because they are driving in a more efficient manner than the EPA test standard. https://www.fueleconomy.gov/feg/how_tested.shtml
My screen shot was when my Jeep was 11 months old. Not a lot of miles on it at just under 7,000, but still not fresh off the lot.Exactly. How are some people getting such high numbers?
Honestly, I call bs.
Most screenshots are of brand spanking new Jeeps. Mine was like that first few tank fill ups.
Anyone with 5000 miles plus on there Jeep can claim these numbers?
See above. They have to, because they have to report the average, as tested by the required methods.Why is Jeep claiming much lower averages then?
Don't forget people ALSO get below the advertised average. Jeep doesn't have to claim the low end either, they only report the average.
This is probably the biggest factor in efficiency. These things are, and always have been, like driving a wall (or a barn ) down the roadway. The faster you go the more it has to work to overcome the wind.....Just driving 60 mph instead of 70 mph, will reduce the horsepower required around 30% or more.......
Because the state auditor certifies the pump, and they place their seal on it.People always say the computer is optimistic. What makes people think the gas pump is telling you the correct amount of gas that you filled up with?
