scorpionsix
I just recently put my 2020 JLUR back into service after sitting on a consignment lot for a few months (decided to keep it after all). Ever since I picked it up, there has been a battery voltage message on the dash. It starts fine and the "dash volt meter" sometimes gets as high at 14.0 but is usually in the mid 13s. Yesterday I drove to the nearby Batteries Plus where I had purchased a H7 Duracell 750 CCA battery early this year. The battery tested fine but the tech said the alternator was weak. I didn't get the reading and am going to go to O'Reilly for a second test/opinion but this time will get the reading for the alternator. Presuming the second test/second voltmeter confirms the first test, should I in fact trust that and plan to purchase a new alternator or is there something else that might be the source of the battery voltage message. I do have the secondary battery disconnected via the negative terminal cable and fuse F42 method.
