Positive outcomes of mopar 2 inch lift kit
  1. Coach53
    Coach53 Member
    Vehicle(s):
    2018 jeep JL sport, 1999 TJ
    Dec 14, 2019
    Kentucky
    Liked:
    Occupation:
    I have a 2018 JL Sport that I would like to lift with the mopar 2" lift kit. I have read the posts in the suspension section and really only see issues with bowed springs, death wobble, bump steering and rear end float. I have had all those issues on older YJ's and TJ's but only when I went over 3.5 inches of lift.
    I would like to hear from anyone that has a 2" mopar lift on their JL with positive outcomes. I have to assume the majority of the 2" lifts have no issues but would like to hear some support in favor of the kit.
  2. Carlton
    Carlton Well-Known Member
    Vehicle(s):
    Jeeps lots of jeeps
    Sep 2, 2018
    Chicago
    2,216
    Liked:
    1,914
    Most people are getting 3+ inches from the mopar 2" kit.
    It is actually a great riding kit if you add some additional parts. Adjustable front track bar, Rock Krawler front spring perches, and geometry brackets.
  3. Halstem1
    Halstem1 Well-Known Member
    First Name:
    Vehicle(s):
    Jun 23, 2019
    Grimes, IA
    308
    Liked:
    128
    I had an issue but it was an install issue. I agree with the above guys though, I added my own Rancho track bars front and rear (350$) and I love the lift. I came from a '17 JK strait to a lifted JL (the dealer lifted it before I purchased). I think it rides better than my '17 but very similar to stock. Loaded up it doesn't sag in the back. 10,000 miles and still feels awesome.
  4. OnlyOne
    OnlyOne Well-Known Member
    Vehicle(s):
    2019 JLR Bikini Turbo on 37’s /2018 Ram Power Wagon On 37’s
    Feb 18, 2018
    Eagle, Colorado
    1,245
    Liked:
    1,840
    Mine is terrific.
  5. AnnDee4444
    AnnDee4444 Well-Known Member
    Vehicle(s):
    Jeep
    Jan 14, 2019
    Earth
    1,029
    Liked:
    962
    I don't own the Mopar lift kit, but my advice is to break it down by component. From what I've read, the shocks are great, but don't have enough travel for the lift that the kit gives. I would think that they are better suited to an actual 2" lift. In my opinion the control arms are not long enough to provide adequate caster either, but this is more of a personal preference. Some of the (early?) kits suffered from spring bowing.
    At the end of the day, the majority of the cost of the Mopar kit is in the shocks. The springs & control arms are not the expensive portion of the kit, so I wouldn't feel that bad about throwing one or the other away and choosing the kit just for the shocks (as long as the price was right). FWIW: A true 2" spring would help the caster issues & shock length issues that the kit has.
    word302 and Roky like this.
  6. OnlyOne
    Vehicle(s):
    Feb 18, 2018
    Eagle, Colorado
    1,245
    Liked:
    1,840
    Also something to realize is the shocks are plenty long enough. They are fine for a 2" lift. If I recall, they are the same extended length as the fox 2.0 for 2-3" lifts. Almost all aftermarket springs are built to hold heavy accessories, like winches, bumpers etc. Many times the dealers who ordered and installed them are idiots. They ordered the wrong spring kits for the wrong applications. Like 4 door springs on two doors and Rubi springs on sports. The Mopar lower control arms that come with the kit are plenty long enough for the correct kit. Lots of misinformation out there to sift through. I did install the RK correction pads. The springs weren't bowing but since I installed MC bumpstops, I figured why not.
    All that said and I know you didn't ask for my opinion, for the money I would be on the Synergy bandwagon, before the Mopar kit. Yes, you will spend a bit more because of shocks but the rest is worth it. I will say the Mopar shocks are the best riding shocks in this category. For the money though, Synergy all day. A correct Mopar kit will serve you well if that's what you choose.
    MNWrangx2 likes this.
  7. OP
    Coach53
    Coach53 Member
    Vehicle(s):
    Dec 14, 2019
    Kentucky
    Liked:
    Occupation:
    Thanks to all for the input. Sounds to me the mopar kit is good quality, but enhancements are needed to obtain acceptable performance.
    donmontalvo and Roky like this.
  8. sourdough
    sourdough Well-Known Member
    First Name:
    Ben
    Vehicle(s):
    Golf, Highlander,Ram3500 diesel 4x4 with Tiger RV coach, JLR
    Nov 12, 2017
    93013
    461
    Liked:
    933
    Occupation:
    done BTDT
    Garage Profiles:
    #8 Jan 19, 2020
    Yesterday, I had my JLR with 37's and Mopar lift on MetalCloaks flex trailer. I was concerned having heard about overfex resulting in brake line, shock, and steering issues. Happy to report MC rep. found no issues of any kind.
    The shocks and bump stops are right. Tires have clearance, brake lines are fine and the SteerSmart track bar and Synergy T.B./sector shaft brace plays together.
    I have had to stuff wheels on several trails and it's good to verify nothing hits or rubs.
  9. Cypher
    Cypher Well-Known Member
    First Name:
    J
    Vehicle(s):
    2020 Jeep Wrangler Unlimited Rubicon
    Feb 8, 2018
    AZ
    1,396
    Liked:
    1,071
    Occupation:
    Cybersecurity Leader
    Garage Profiles:
    What kind of numbers did you get?
  10. Cypher
    First Name:
    J
    Vehicle(s):
    Feb 8, 2018
    AZ
    1,396
    Liked:
    1,071
    Occupation:
    Garage Profiles:
    Did you sell your Mopar lift? I have been looking for a set of the Mopar lift Fox shocks (or a whole kit) but seems there are not many out there used. I am looking at a few options for my Rubicon, but looking to stay on the cheaper shade for now as I will most likely be selling / trading in my Rubicon this year. I want to stick with Mopar parts for that reason
  11. Canyonero JL
    Canyonero JL Active Member
    First Name:
    Krusty
    Vehicle(s):
    2018 Jeep Rubicon JL Unlimited
    Nov 22, 2019
    North of Dallas
    Liked:
    I love my Mopar kit (for the 2.0L unlimited). Only word or advice is to double check your spring location for each wheel. The springs are different, as I believe the springs on the left side of the Jeep are slightly longer than the right, to account for the fact that the left side of the Jeep is slightly heavier (gas tank, maybe?). This info is in the Mopar instructions.
  12. Cypher
    First Name:
    J
    Vehicle(s):
    Feb 8, 2018
    AZ
    1,396
    Liked:
    1,071
    Occupation:
    Garage Profiles:
    Need something different. I have an artificial knee and the implant has failed. Due to that I am not able to get out and use the Rubicon like I planned. Even after I have the revision, it will be tough for me to do the harder stuff anymore. My plan is to get something a little more comfortable (hopefully the Bronco) that can do what I need while also being much more comfortable on long highway trips. May also swap back to another Grand Cherokee Trailhawk. I loved my old one, and it would also do what I need it to do. With that Grand Cherokee Trailhawk the hard part will be wait for the redesign or not, and go with the Hemi or Diesel. As of now I would go with the Hemi as it is much simpler and should be easier to maintain. My JL (current one) is a 2020, so can't get much newer than that. My 2018 and 2019 were both repurchased.
    Roky likes this.
  13. Jimmy_jak
    Jimmy_jak Well-Known Member
    Vehicle(s):
    2019 JLU Sport S
    Jul 20, 2019
    Central Florida
    308
    Liked:
    248
    Garage Profiles:
    Went Metalcloak over Mopar because it makes sense. If I have to buy more parts to make the Mopar kit work then what's the point
    word302 likes this.
  14. Carlton
    Vehicle(s):
    Jeeps lots of jeeps
    Sep 2, 2018
    Chicago
    2,216
    Liked:
    1,914
    Even if you add an adjustable track bar, spring perches, and geo brackets/lower arms you come in way under a Metal Cloak kit. Additionally you get much better shocks and no hassle from the dealership when they see it is a mopar kit.
    Lensync58, sourdough and Cypher like this.
  15. AnnDee4444
    Vehicle(s):
    Jeep
    Jan 14, 2019
    Earth
    1,029
    Liked:
    962
    Warranty?
Loading...
Share This Page
