Positive Offset Wheel Choices
jdhunt0
Kentucky
2019 Wrangler Unlimited
I may be in the minority here, but I would prefer my tires to not stick out way past the fenders. What I have been looking for are wheels 17x8.5 with an offset of +18 to +25. There are not many that fit these specs especially that are light weight. I plan post wheels that I find in this thread and hope others do as well.
jdhunt0
jdhunt0
Kentucky
I'm not sure what wheels these are, but this is drock317's Jeep with +18 offset.
Hayseed_JLUR
Midwest
2019 JLUR, 2015 JKU
I have the Pintlers and they are not heavy. I saw someone weigh them under 30lbs.
AnnDee4444
'18 JLR 2.0
Not sure if this fits the theme of the thread, but the Grand Cherokee WK2 wheels have the same bolt pattern, are available in 17" x 8", and have 56.4mm offset. The extra 1/2" width over stock would allow more tire sizes to be mounted, and with a 1.75" spacer the effective offset would be +12mm. If you consider 18" wheels, even more styles are available.
http://www.wk2jeeps.com/wk2_wheels.htm
jdhunt0
jdhunt0
Kentucky
The Raceline 944B OUTLANDER is a +18 and I think around 27lbs. But I'm not sure if I care for the looks.
LBK454
Larry
Wyoming
2019 JLUR
I believe the AEV are +25mm offset (Borah 5.72”; Pinter / Saverge 5.77”) and the MOPAR Off-road are +12mm (5.22”).
blnewt
New Mexico
Just ask @cosine he knows!
ATX Ravine 17x8.5 +10 & weigh about 30 lbs, these are on 295/70s
Sting_NC_USA
Michael
Greensboro, NC
If you go with that offset, just understand that adding a lift later will likely cause issues. A spacer lift should be fine, though most lifts require 4.5 inches of backspacing to avoid rubbing the control arms. 3.5 inches for 37+. Admittedly, I do love the look of having the tires tucked in!
jdhunt0
jdhunt0
Kentucky
My plan is to go with the Dynatrac lift. I do not remember seeing a backspace requirement, but I'll call and ask.
Sting_NC_USA
Michael
Greensboro, NC
The concern comes about when you add lower control arms (LCA's). If you're adding something like the Dynatrac JL20-1X5310-A EnduroSport 2" Lift with Fox Shocks, it doesn't include LCA's. At that point, it would simply matter if the tire was already hitting your existing LCA's.
blnewt
New Mexico
jdhunt0
jdhunt0
Kentucky
Here's a list on Custom offsets, on the left column you can select offsets, I selected +25 but it shows a list of +18 thru +25, just have to go through a few offset selections to show the full lineup of positive offset wheels.
https://www.customwheeloffset.com/store/wheels?sort=popular&suspension=Leveling Kit&modification=No trimming&dia=17&width=8.5&offset=25&bolt=5x5,5x127
I had noticed that too. Why when I pick +25 does it show everything from +10 to +30? And I don't think they show weights of many wheels if I remember right.
