aCeMedic13
- Ambrose
- Dec 29, 2017
- San Antonio, Texas
- 2018 Jeep Wrangler JLU Rubicon
- Occupation
- RN/Paramedic
- Vehicle Showcase
- 1
Working list... Feel free to add.
Rating (C,D,E) Ply - Thickness of sidewall. Additional protection + load = stiffer ride.
Actual diameters are listed - Width should also be taken into consideration dependent on wheel/rim of choice.
A three-peak mountain snowflake (3PMSF) symbol branded on a tire's sidewall indicates the tire meets required performance criteria in snow testing to be considered severe snow service-rated. 3PMSF-branded all-season and all-terrain tires cannot match the traction of dedicated winter / snow tires in all winter weather conditions and should not be considered a replacement for where and when a dedicated winter tire is needed.
Listed Tire pressures are manufacturer recommendations (See post #25 for explanation).
BF Goodrich T/A KO2
Class : All Terrain
Three-Peak Mountain Snowflake symbol (3PMSF)
33 (Stock Rubicon Tires)
LT285/70R17 C Rating (Actual diameter : 32.8) WEIGHT : 51 lbs Width : 11.5"
Recommended Tire Pressure (JLU) : 37 PSI
Options :
LT315/70R17 C Rating (Actual diameter : 34.4) WEIGHT : 64.4 lbs Width : 12.7"
LT315/70R17 E Rating (Black Letters) (Actual diameter : 34.4) WEIGHT : 65.17 lbs Width : 12.7"
35X12.50R17 E Rating (White Letters) (Actual diameter : 34.5) WEIGHT : 66.2 lbs Width : 12.5"
Options :
37X12.50R17 D Rating (Actual diameter : 36.5) WEIGHT : 68.2 lbs
BF Goodrich KM3
Class : Mud Terrain
Options :
LT315/70R17 E Rating (Actual Diameter 34.4) Weight : 65.7 lbs Width : 12.7
35X12.50R17 E Rating (Actual Diameter 34.5) Weight : 74.38 Width : 12.5
Cooper Discoverer STT Pro
Class : Mud Terrain
Options :
LT315/70R17 E Rated (Actual Diameter: 34.57) WEIGHT : 66 lbs Width : 10"
Options :
37X12.50R17LT D Rated (Actual Diameter: 36.77) WEIGHT : 75 lbs Width : 10.2"
37X13.50R17LT E Rated (Actual Diameter: 36.77) WEIGHT : 84 lbs Width : 10.98"
Cooper Discoverer S/T Maxx
Class : Hybrid
Options :
LT315/70R17 D Rated (Actual Diameter: 34.57) WEIGHT : 66 lbs Width : 12.8"
LT285/75R17 E Rated (Actual Diameter: 34.06) WEIGHT : 65 lbs Width : 11.1"
Options :
37X12.50R17LT D Rated (Actual Diameter: 36.89) WEIGHT : 79 lbs Width : 13.1"
Mastercraft MXT
Class : Mud Terrain
Options :
LT315/70R17 D Rated (Actual Diameter: 36.77) WEIGHT : 64 lbs Width : 12.8"
35X12.50R17LT E Rated (Actual Diameter: 34.76) WEIGHT : 64 lbs Width : 12.7"
Options :
37X12.50R17LT D Rated (Actual Diameter: 36.69) WEIGHT : 70 lbs Width : 13.1"
Toyo Open Country M/T
Class : Mud Terrain
Options :
LT315/70R17 E Rating (Actual Diameter: 34.6) WEIGHT : 78 lbs Width : 12.7
35X12.50R17LT E Rating (Actual Diameter: 34.8) WEIGHT : 78 lbs Width : 13.2
Options :
37X12.50R17LT D Rating (Actual Diameter: 36.8) WEIGHT : 84 lbs Width : 12.5
37X13.50R17LT E Rating (Actual Diameter: 37) WEIGHT : 94 lbs Width : 14.6
Nitto Ridge Grapplers
Class : Hybrid Light Truck
Options :
LT315/70R17 E Rated (Actual Diameter: 34.41) WEIGHT : 70.83 lbs Width : 12.72" JLU PSI : 30
35x12.50R17LT E Rated (Actual Diameter: 34.76) WEIGHT : 75.45 lbs Width : 12.52" JLU PSI : 31
Options :
37x12.50R17LT D Rated (Actual Diameter: 36.77) WEIGHT : 81.48 lbs Width : 12.52" JLU PSI : 26
37x13.50R17LT E Rated (Actual Diameter: 36.77) WEIGHT : 87.04 lbs Width : 13.58" JLU PSI : <25
Nitto Trail Grapplers
Class : Mud Terrain Light Truck
Options :
35x11.50R17LT C Rated (Actual Diameter: 34.76) WEIGHT : 72.6 lbs Width : 11.42"
LT315/70R17 D Rated (Actual Diameter: 34.61) WEIGHT : 76.83 lbs Width : 13.27"
35x12.50R17LT E Rated (Actual Diameter: 34.84) WEIGHT : 79.89 lbs Width : 13.19"
Options :
37x12.50R17LT D E Rated (Actual Diameter: 36.85) WEIGHT : 84.78 lbs Width : 13.43"
Nitto Mud Grapplers
Class : Mud Terrain Truck
Options :
35x12.50R17LT E (Actual Diameter: 34.76) WEIGHT : 79.05 lbs Width : 13.19"
Options :
37x13.50R17LT E (Actual Diameter: 37.05) WEIGHT : 97 lbs Width : 14.57"
Goodyear Wrangler Duratrac
Class : All Terrain
Options :
LT315/70R17 D Rating (Actual Diameter: 34.4) WEIGHT : 60 lbs Width : 12.7"
35X12.50R17 E Rating (Actual Diameter: 34.8) WEIGHT : 66 lbs Width : N/A
Options : N/A
Milestar Patagonia M/T
Class : Mud Terrain
Options :
LT315/70R17 (35X12.50R17LT) D Rating (Actual Diameter: 34.7) WEIGHT : 67.92 lbs Width : 12.7"
Options :
37X12.50R17LT D Rating (Actual Diameter: 36.8) WEIGHT : 71.3 lbs Width : 12.5"
BF Goodrich T/A KO2
Class : All Terrain
Options :
Options :
BF Goodrich KM3
Class : Mud Terrain
Options :
Class : Mud Terrain
Options :
Options :
Class : Hybrid
Options :
Options :
Mastercraft MXT
Class : Mud Terrain
Options :
Options :
Class : Mud Terrain
Options :
Options :
Options :
Options :
Options :
Options :
Nitto Mud Grapplers
Options :
Options :
Class : All Terrain
Options :
Options : N/A
Class : Mud Terrain
Options :
Options :
