KnG818
That wont rustPrimer absorbs moisture which creates rust . I would have it painted
Umm.......WUTPrimer absorbs moisture which creates rust . I would have it painted
I was hoping it was wax, its not...You wrote you washed and wax it, before you noticed. Is there any chance that is wax residue?
The hinges weren't adjusted at any time. The paint line fades into the primer all around the hinge. Every hinge on the Jeep has some primer showing all around the hinge. Every hinge. There is even primer showing under the back side of the hinges.Any pictures of what it looked like before?
Certain they removed the tailgate to paint something...was it the hinges that needed touch-up??
Looks like they didnt realign the hinges on the tailgate properly.
At the factory they paint it assembled with the hinges on(same for doors, windshield, tailgate, etc..) which is why there is no color behind the hinge.
I recently installed atlas door hinge steps and when you remove the hinges its unpainted behind it and you have to realign the hinges just right when reinstalling or you will see that unpainted outline like you have in your photo.
If your good with your hands try loosening the hinges and realign the hinges on the tailgate. Or have the dealer do it, it can be tricky. Touch up the bolt areas thereafter with touch up paint.
Good luck.
Tailgate is magnesium.Isn't the tailgate aluminum? If so then rust shouldn't be an issue at all.
Ah sh!#. Really? I've had decades of chasing broken and cracked magnesium parts in the aircraft industry. It always looks like a great material to the original designer. But the fatigue properties of mag suck. Then, years later, someone has to either keep replacing parts or design an aluminum replacement. The corrosion properties of mag are also poor.Tailgate is magnesium.
Brett
Could be wrong, but I think the internal structure is mag but the skin is not.Ah sh!#. Really? I've had decades of chasing broken and cracked magnesium parts in the aircraft industry. It always looks like a great material to the original designer. But the fatigue properties of mag suck. Then, years later, someone has to either keep replacing parts or design an aluminum replacement. The corrosion properties of mag are also poor.
Hi Pete,Update...
I went to the dealer and they confirmed the issue, primer showing. I went out to the lot and looked at the other Wranglers. They all have primer showing. Its just worse on the black and blue wranglers because of the contrast. My tailgate hinges are the worst of all the Jeeps that I saw today. I didn't notice the model years of the Jeeps that I saw on the lot, so I don't know if its a 2020 "thing."
The dealer sent me to a collision shop that they do business with. The guy at the shop saw a bunch of other blemishes on the car. He was amazed at the lack of quality. His estimate was $3200! His estimate included removing and repainting the tail gate, the four doors, the hood and front quarter panels. I'm not sure of how to proceed...do I want a nearly-completely repainted Jeep? ugh!!!
Thats what I've been thinking. Not sure if I want the whole car being repainted. I don't want to have to explain that the Jeep was repainted due to an inadequate job at the factory and not due to an accident. Either explanation would give a potential buyer pause. I submitted my claim to FCA through the dealer (who has been great helping me through this situation), so we'll see what FCA has to say.Just a thought, any repair will be on the "carfax" and there will be diminished value. yes? Tennessee appears to be a "diminished value" state.
I've seen repair paint that doesn't hold up as well as factory baked on paint. What's the likelyhood 4-5 years down the road you have a problem with the paint and you're left holding the bag?
Frankly, your situation sucks, but I'd opt for the dealer just giving you some discount and have a touch-up airbrush guy do a minimally invasive touch-up of the very local area. Then, if the paint fails in that area 4-5 years down the road, it would be a minimal repair.
Yea, my 2019 Jeep looks like that too, but I have a hinge reinforcement kit which is likely covering up more of the problem. It's a Jeep thing, and not in the good way. Best way to deal with it is mutter "jeep" under your breath, and enjoy driving with the top down. Then, head out to a trail and get the fenders and doors pinstriped on a shrub or rock. Better yet, get the fenders torn clean off, then replace with aftermarket. Alternatively, park the Jeep in a lot under a tree, everyday, untill the birds bomb it out real bad and you get cracks in the clear coat. I should have waxed it first day back from the dealer, but life got busy.Update...
