dshark1
- Sunny
- Jun 29, 2021
- Fort Lauderdale, FL
- 2021 Rubicon JLR
Hey Man ,, Thx so much for that! So helpful…. They really do look awesome on. Now I just have to decide if I want to go through the trouble of getting them installed.Not meant to be an insult to him, but I'd say there's no chance his was fine. It was just probably before he had tested much. In fact it's not my story to tell, but I've seen other posts of his more recently where's he's gotten rid of them entirely due to corrosion on the screws.
I've known multiple people in my local club with these -- all of us followed the same path, had the taillight guards first, no issue, added the tailgate reinforcement afterward, problem. Doesn't matter XR or not. One guy didn't realize there would be an issue, ended up cracking his taillight guard. Another tried to put rubber on his to deflect the tailgate, but that doesn't work -- tailgate is way too heavy to be deflected by the taillight guard. He moved to cut it after I told him about it.
The problem is here, this is my original pic pre-cut. When you open the tailgate all the way, green will touch green, yellow will touch yellow. You can easily test it by unscrewing the tail light (so you don't harm anything), have one person hold it in place, and another opening the tailgate. It will push on the taillight guard quite a bit.
The solution for green is to just cut it off with a Dremel. We tried not cutting off the whole piece, going very slowly and re-testing. However, we kept touching, and we decided it looked better than half a nub. Yellow we just ground down. It cuts very easily with the Dremel (in fact, one guy in the club did his in place still mounted on the Jeep). We started with it on all at once also figured out halfway through it's a lot shorter work if you start by taking the faceplate off. A mid-process pic:
I did find this video earlier which was all of our inspiration to cut. It demonstrates the problem: (my green spots in the picture). Later on in the video he cuts and mentions how yellow is a problem too.
In summary if you like the look of both pieces together (as I and others do), cutting/grinding is the solution. Not that hard if you have the tools.
