Please explain like I am a 5 year old. New Tires, Gas Mileage drop.
  1. Sorbs
    Sorbs Well-Known Member
    First Name:
    Brian & Sunny
    Vehicle(s):
    20' Gladiator LE, 18' JLR 6-spd 2DR, 15' Hellcat Challenger
    Aug 3, 2018
    Colorado Springs
    448
    Liked:
    820
    You might wait for the ECM/PCM to adjust to your new setup. Modern ECM/PCM's adapt to driving conditions and your driving habits.
    Follow these steps to reset your EMC/PCM:
    1. Disconnect the battery by removing the Negative battery cable (This will ensure that any possibility of grounding the power side to the vehicle does not happen.)
    2. Disconnect the Positive battery cable
    3. Allow a five minutes to pass before reconnecting the cables
    4. Reconnect the positive cable to the battery
    5. Reconnect the negative cable to the battery
    6. Turn the Vehicle on
    The ECM/PCM parameters for all sensor calibration monitors have now been reset. It can take anywhere from a few minutes to a few days for all of the system parameters to be restored within the unit.
    lepcat and Roky like this.
  2. JLUin818
    JLUin818 Well-Known Member
    First Name:
    Vehicle(s):
    2018 JLU
    May 29, 2018
    San Fernando Valley
    1,034
    Liked:
    1,007
    is that going to work with the second battery? Do all JLs have a second battery?
    lepcat likes this.
  3. Sorbs
    First Name:
    Brian & Sunny
    Vehicle(s):
    Aug 3, 2018
    Colorado Springs
    448
    Liked:
    820
    The second battery is for the ESS system. Although it will prevent the vehicle from starting if dead it doesn't provide primary power to the PCM.
    lepcat and JLUin818 like this.
  4. OP
    lepcat
    lepcat Well-Known Member
    First Name:
    j
    Vehicle(s):
    2018 Wrangler Unlimited JL Sport S
    Sep 27, 2019
    texas
    49
    Liked:
    How much did yours drop? I honestly expected a little bit of a drop but not quite as much as I got. It has been windy the last few days since I changed over. So I think I’ll get a better baseline highway and city when the wind stops.
  5. OP
    lepcat
    First Name:
    j
    Vehicle(s):
    Sep 27, 2019
    texas
    49
    Liked:
    Yes I’m very happy. Kept my stock suspension so the rides really nice in town and on the highway. Doesn’t walk much if at all. It was a rated tires will definitely grab a groove in the highway or rats left by semi’s. But that’s to be expected.
  6. JLUin818
    First Name:
    Vehicle(s):
    2018 JLU
    May 29, 2018
    San Fernando Valley
    1,034
    Liked:
    1,007
    i havent done any serious calculations but on rubi 33s i would often hit 28mpg on the freeway with cruise control on. Now its like mid to low 20s.
    lepcat likes this.
  7. wrangster
    wrangster Well-Known Member
    First Name:
    Ray
    Vehicle(s):
    2018 JLUS
    Dec 8, 2018
    243
    Liked:
    199
    Occupation:
    Retired and happy!
    Garage Profiles:
    Just a bad choice with 3.45 gears, there are graphs for tire to gear ratio.
    lepcat likes this.
  8. wolfdog
    wolfdog Well-Known Member
    First Name:
    George
    Vehicle(s):
    2006 Yamaha FJR1300, 2015 Cherokee TH, 2018 JLU Sahara
    Apr 14, 2018
    Southern Massachusetts
    340
    Liked:
    193
    Occupation:
    Maritime Artisan,Mayflower II
    I'm kinda thinkin' a JLU or JL Rubi with stock tires downhill with a big tailwind and in neutral wouldn't get 28mpg???? Just sayin'?
    Go Jeep!!!
    NPE102414 and lepcat like this.
  9. Spank
    Spank Well-Known Member
    Vehicle(s):
    2018 Jeep Wrangler Unlimited Rubicon, 2018 Dodge Challenger RT Scat Pack
    Mar 29, 2017
    1,025
    Liked:
    1,276
    I don't think the fuel economy calculations are adjusted at all to compensate for changes to the drivetrain when you adjust values such as tire size or even gear ratio. I could be wrong and maybe its different for the JL, but this was certainly true for the JK. The JK had always maintained its set range based on the stock configuration of the vehicle. My regeared '14 with 35s and 4.56s would still report the same general averages even though I was definitely getting less fuel economy in the city.
    I'm running 37s on stock 4.10s on my JL and my fuel economy numbers remain largely unchanged in the EVIC, but I know for damn sure I'm not getting 18mpg on the highway with these meats.
    wolfdog and lepcat like this.
  10. JimLee
    JimLee Well-Known Member
    First Name:
    Jim
    Vehicle(s):
    '19 JLU
    Mar 29, 2019
    Too damn close to Death Valley
    397
    Liked:
    714
    My MPG's dropped from 18.5 to 16.1 average going to 35's, it is what it is. I doubt i'll gain anything back when I go to D60 axles and 37's with 4.88 gearing, but hopefully it'll hold somewhere close to there. Would be nice if someone actually started producing an aux fuel tank for the JL, which will ironically drop your MPG's even more with all the extra weight. Oh well, can't own an offroad monster and be a gas miser, have to accept the realities.
    lepcat likes this.
  11. OP
    lepcat
    First Name:
    j
    Vehicle(s):
    Sep 27, 2019
    texas
    49
    Liked:
    Dang. Okay. Thanks for the reply.
  12. wrangster
    First Name:
    Ray
    Vehicle(s):
    2018 JLUS
    Dec 8, 2018
    243
    Liked:
    199
    Occupation:
    Retired and happy!
    Garage Profiles:
    Lots of jeepers here fail to mention braking with the larger heavier tires. Going to a larger brake set would be another smart choice! so what we have is : axles, gears, tires, rims, brakes etc. etc. Think I would rather go off road onto rocks and such with a Polaris and much cheaper to. Just my take on this! enjoy whatever you love to do.
  13. JLUin818
    First Name:
    Vehicle(s):
    2018 JLU
    May 29, 2018
    San Fernando Valley
    1,034
    Liked:
    1,007
    i havent noticed any detriment to my braking. I also dont drive my jeep like sports car either. Upgrading the brakes is not cheap and not worth it imo.
  14. Dagwood
    Dagwood Well-Known Member
    First Name:
    Vehicle(s):
    2019 Jeep JL, 1999 Jeep xj, 2008 Scion XB, 2015 Scion XB, 1966 Ford F100, 1969 Oldsmobile
    Mar 4, 2019
    Alabama
    422
    Liked:
    781
    Please do, it will make this post far more entertaining.
    Rogues Gambit likes this.
  15. Dagwood
    First Name:
    Vehicle(s):
    Mar 4, 2019
    Alabama
    422
    Liked:
    781
    Since it's a four door I'll start.
    When the wheels on the bus go round and round.
Loading...
Share This Page
