omnitonic
- Michael
- Apr 20, 2021
- Southwest Virginia
- 2021 JLU Willys in Sarge Green
- Occupation
- truck driver
I'm installing the TeraFlex 2.5" base lift with Rock Krawler track bars, the cheap shocks, the plain Falcon jounce bumpers, and I'm reusing the Mopar lift LCAs I installed with my Rubi takeoff lift.
I got the front mostly finished today. I still need to torque the track bar and the control arms.
First question: The TeraFlex install vid wants me to undo and discard that brake line clip that rides on the LCA. I find myself wondering if I can REALLY flex this thing out to a point where that bracket would put the brake line in a bind. Maybe. I'm on the fence about that one, but I should probably follow TeraFlex's instructions.
Ah, an install note: I installed the first bump stop first, and then I had to use a spring compressor to get the spring on. On the other side, I followed the instructions, and zip tied the bump stop to the spring, then screwed the bump stop down while it was inside the spring.
Anyway, if I had it to do over again, I think it was less of a pain in the ass to use the spring compressors. It definitely was a pain in the ass, but the one where I followed the instructions was just pure hell. On the spring compressor side, I used a ratchet that could spin almost a full 360 degrees, and I got the bump stop tied down fairly quickly and easily, then I had to faff about with the spring compressors, which sucked. On the follow the instructions side, I had to use an allen key, and screwing that thing down on the inside of a spring was one of the most ridiculous automotive things I've ever dealt with. Stick it between coils, turn until it hits the next coil, back it off, repeat for 20 minutes, gaining about 7/32" with each pass. Yeesh. That sucked!
Next question: When I did my Rubi takeoff lift, the alignment seemed fine, and I never did take it to a shop. After I did this lift, it appears my front wheels are just STUPIDLY toed out. I tried to center the wheels, and I chased my tail for 20 minutes. If this side looks straight, that side is angled sharply. I'd say I have maybe 1.5" of toe out. Is that typical with a bigger lift like this? Does it indicate that I screwed something up?
I'm going to try to get the toe closer before I take it to a shop for an alignment.
Next question: I never tried to do anything like installing a track bar before, and I wonder if I dooed it right. I bolted the frame side just pretty much finger tight. On the axle side, the Heim joint was at least 0.006" wider than the slot in the mounting bracket. I imagine the normal solution to this would be to grind on the bracket. I own a lathe, so I just chucked these inserts in and shaved about 0.003" off the outside face of both parts. That still didn't remotely fit, and I ended up making two more trips. I ultimately shaved off probably 0.006" from both parts, leaving the pair about 0.012" smaller than it started. I also chamfered the edges slightly, to make it easier to get the thing started into the bracket. It was still tricky to tap into place, so I feel it was snug enough.
So anyway, my next move was to measure from the hole in the top of the spring bucket to the inside edge of the tire. I got 6.75" and 7.25". I hooked a ratchet strap between the frame and the steering knuckle, and ratched the body over until I got pretty close to 7" and 7". Then I adjusted the track bar until the bolt would go through the hole, which involved putting another few clicks on the strap. You can only adjust the thing in half turn increments, and a quarter turn was what I needed. Anyway, it came out at something like 6.875, and 7.125" Seems like it should be plenty close enough.
I think I'm out of questions now. I'm reasonably confident that I did okay on the other stuff. The TeraFlex kit had good instructions, and a lot of it was the same as the Rubi takeoff lift.
Total trips to Harbor Freight: Just the one. I had to get an even bigger crescent wrench for the ridiculously huge ass jam nut on the track bar.
Useful tip: Use the weird little bent wrench to shove the nut flush with the bottom of the spring mount, then use Vise-Grips to clamp it in place, so you don't have to struggle with dropping the damn thing every 15 seconds. The fit of the nuts on those machine screws is pretty tight, and they are fairly hard to crank down. You aren't spinning it down close to torque and then working the last little bit. You have to work the whoooooole way.
