Plasti-Dip Trail Rated Badge?
flyer92
Nevada
Not sure why the designers made the Trail Rated badge silver, when all the other emblems and decals on my JL are black. Surprisingly, it doesn't really bother me or trigger an OCD attack, but I have some Plasti Dip left over from another project and thought it might be fun to change the badge to black.
That said, I'm just curious if folks typically apply Plasti Dip with the badge installed as-is, or prefer to remove it first. I've never applied Plasti Dip on an installed item, so I am interested in how easy it is and if anyone has some good pointers, advice, etc.
AcesandEights
Aces
So. Oregon
2022 Jeep Rubicon 2D, with extra guacamole
Instead of plasti-dip, I've buried all of mine.
Canucklesammich
2022 JLR
As someone who has replaced this badge, I'll say it's stuck on pretty well. If you removed it, I'm not sure you'd get it attached as strongly as it is from the factory, so I'd vote to tape around it & do it that way.
AcesandEights
Aces
So. Oregon
Sorry, I misunderstood the question.
Multiple places..
@flyer92
They are easy to do in place... no need to remove. Just clean up the badge with rubbing alcohol or similar, tape off and spray multiple light coats of plasti-dip. (Let each coat dry a bit before the next coat) While you are at in do your EZ-Pass..
By the way, Forum Sponsor @Threedom has some terrific BADGE's to replace the side badge, or they can be used if you do an antenna delete or if you just want a custom design badge on the rear of the JL.
Threedom provides pre-cut 3M tape with the badges they sell. With that 3M tape the badge is stuck on there as well as the badge that was placed at the factory.
https://www.jlwranglerforums.com/forum/threads/📢-💥-threedom-custom-design-badges.88010/#post-2045196
Here is a pic of my Tread badge on the rear of my JL..
Jeep Wrangler JL Plasti-Dip Trail Rated Badge? reartreadbadge04
flyer92
flyer92
Nevada
That was my thought as well....thanks. Just wondering how well you can really Plasti Dip the badge when it's installed.
kah.mun.rah
Merenkahre Jr.
Duat
I think you will be ok. Just test it on just one to start with. If you screw it up, just buy another badge on eBay to replace it.
Multiple places..
You can't really "screw it up". Plasti-dip is removable.. Basically you peel plasti off, if you want it off after applying.. It does not mar/discolor say a badge you coat with it.
flyer92
flyer92
Nevada
@flyer92
Thanks...I've been watching videos of others applying Plasti Dip to installed badges on Youtube and agree that it looks pretty easy. Appreciate the recommendation for Threedom's replacement badges too, but I actually like the existing badge. Just looks a little out of place because it doesn't match the other badges and decals.
jhackathorne
Denver
'21 JLUR
Just tape it off well and do several coats. I did both the Jeep logo and Trail Rated as well. Used a tooth pick to clean around the lettering. The badge needed nothing except cleaning a little around it is all.
