Pics please - Mopar 2" lift with 37 in tires
sourdough
left coast
JL
JL Rubicon with Mopar lift, AEV JL Pintle wheels and 37x12.5x17 Cooper STT Pro's
FYI, there was a very slight rub in rear on plastic liner. Easily reshaped bump out spot with a heat gun. No more rubbing when tire is fully stuffed.
jabtyler
Adam
Denver, Co
18 jlur
mine was closer to a 2.5" lift but I assume it will come down a little over time.
I forgot to say I ended up with some deadly wabbles after putting the Mopar kit on. Im pretty sure its a caster issue, Im still working on it with help from CORE off road in Denver. Im going to do some synergy adjustable control arms pretty soon to take care of the problem. its not bad but when I hit some bumps my wheel likes to shake for a second or 2.
SleepEatJeepRepeat
Newport Beach, Ca
2021 JLUR, 2020 Audi Q7
Looking at Jeep stuff all day
did you check your axle position, after a 2” lift I was a full inch off center to the driver side, caused quite a bit of steering instability.. adjustable track bar helped a bunch
jabtyler
Adam
Denver, Co
18 jlur
I put the teraflex track bar on and got it centered. still have some wobble.
SleepEatJeepRepeat
Newport Beach, Ca
I have very little, and decided I am fine with it.. if I had picked the vehicle up like it is now, I wouldn't have never done anything and had been happy.. If it's still to much for you, then everyone talks about pushing the caster to 6" with a cambolt (cheap but you drill a permenent hole) or adjustable lower arms. I haven't tried it but that is what i would have tried next
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
Mopar lift with mastercraft 37s. This is just after install so may still settle some. Do have rough country front track bar and super lift rear bracket.
Have been using the Jeep.
SleepEatJeepRepeat
Newport Beach, Ca
Great pics, I always am too caught up in the moment going thru the real rough stuff like that.. to stop and grab photos.. I wish i did a better job of that..
Donnie210
Donnie
Upstate, South Carolina
2019 Jeep Wrangler Rubicon JL
Just installed. It drives and sounds like a dream!
Mopar 2" lift / Rock Krawler front spring pad correction wedge / RK front adjustable trackbar / RK rear trackbar relocation bracket / Fox steering stabilizer / 20x10 Moto Metal / Nitto Ridge 37x13.5. / K&N CAI / Tazer JL mini
Living Good 357
Big D
Pa
C7 Z06, 07 Dodge Cummins, 900 HP 72 Nova
Got a 2.5 in lift and have 37's. Just took it out this weekend and it rubs in the back and that is without disconnecting the swaybar. There is a small piece I took off in the wheel well which helps but there is still a piece that rubs. If you want to go offroad I highly recommend 3.5 in lift.
Are those 17 or 18 inch wheels
LJ_3M121318
LJ
Los Angeles
2021 4xe Rubicon
Anyone have pics next to other cars? I had been wanting the Mopar lift but can't seem to get good context of how it compares to other regular cars because every picture on the internet is just a solo pic in the open
LJ_3M121318
LJ
Los Angeles
2021 4xe Rubicon
Jeep Wrangler JL Pics please - Mopar 2" lift with 37 in tires 20200316_174709
Did you have to regrear?
