Pics of JL with 33s and Rubicon Suspension?
lchaveyriat
Lucas
Nashville
2020 Jeep Wrangler Unlimited Sport
Any pictures of a sport or sahara with Rubicon suspension and 33s? Also, how is the ride quality compared to stock ride quality?
jonahgetz
Jonah
Washington St.
2021 JLU Billet Silver
Hereā€™s my 2021 with rubicon takeoff from a recon, so the best springs and shocks that give the most lift. I think I got 2 inch or more. Make sure you look at part numbers because not all rubi takeoffs are created equal. Some offer more lift if they have the tow package etc. so go for a rubicon recon takeoff for most lift.
itā€™s a lot more playful and less stiff. i never realized how much the stock suspension was lacking until I did the swap. Itā€™s worlds different. I enjoy the ride much better. A buddy thats owned rubiconā€™s gave it a drive and said it rides identical to rubiconā€™s.
Running 285/70/17 BFG KO2s
Jeep Wrangler JL Pics of JL with 33s and Rubicon Suspension? FFE2F272-7A86-4458-84F2-4264F2A3C940
Jeep Wrangler JL Pics of JL with 33s and Rubicon Suspension? 1D6E11C7-E14A-414F-8419-78C7D1C1B563
ThirtyOne
Chapel Hill, NC
www.jeepdoodles.com
Jeep Wrangler JL Pics of JL with 33s and Rubicon Suspension? 8DC8210F-814E-4BAD-9A29-C89B262110EA
geem03
Gary
New Brunswick Canada
2019 Jeep Wrangler Sport
RN/ Firefighter
Rides stiffer...
MarkM
Fort Collins, CO
2019 JL Sahara 3.6
Project Manager
Here is my MY19 Sahara right after the upgrade. A guy in town was adding a ton of after market parts to his Rubi, so I scored his rims, springs and shocks, etc. for cheap! The only non-factory parts change I made was to add 1/2" spacers on the front springs to level the front rake out a bit.
I recently added longer front LCAs (about 1/4" longer than original) to get the front caster a little back in line with stock after a small death wobble experience.
The ride is stiffer, certainly! However, it is not bad at all. I noticed the change before I even got to my road on the test drive.
I don't know the spring rates on the Rubi springs, but they were all about 2 inches longer than the Sahara springs, so, I only attributed lift to that and most of the ride change to the Rubi shocks' internal valving. I don't know those details, but they are all designed to work on the same platform, so nothing would be too dramatic.
Tires are 285/70-17, which I had on about a week before I broke down and did the springs. I didn't really feel a change there, maybe a tad softer with the higher sidewalls, compare to the 18s they replaced. I run the same pressure, 36 PSI, as the Rubis at the dealership all show that on their door tags.
And, yeah, the garage was a fricking mess! I have too many toys! No, actually, I don't!
HTH,
M
Jeep Wrangler JL Pics of JL with 33s and Rubicon Suspension? 20210911_125415
Jeep Wrangler JL Pics of JL with 33s and Rubicon Suspension? 20210905_172237
Fourthandlong5
Pottstown, PA
2019 Wrangler JL Sport
Rubicon take offs and 1/2ā€ coil spacer up front. Ride is definitely firmer over the Sport suspension which I like. I added Mopar LCA's as well for better caster.
Jeep Wrangler JL Pics of JL with 33s and Rubicon Suspension? 538260E3-96E9-4E37-AD46-6C1D3CA3B8FE
