I did raise the light. You have to pull the heat shrink off the back of the grommet so you can pull more wire through from inside the tailgate.Looks great!
Question - did you extend your 3rd brake light up so that it is visible above your spare tire?
I'm able to raise my brake light up when I do not use a relo bracket, but once I put the relo bracket on, there is not enough wire to allow the brake light to extend up. And I believe your RC relo bracket lifts higher than the SmittyBilt bracket I was using.
Awesome - any chance you have any photos of what this look like to help me visualize it? Do you still have the seal up against the tailgate?I did raise the light. You have to pull the heat shrink off the back of the grommet so you can pull more wire through from inside the tailgate.
-Eli
