WolfMaster
To permanently disable the auto-stop feature on your 2020 Jeep Gladiator without having to spend money on and expensive gadget you can follow these simple instructions.
1. On the driver's side door locate the access panel to the wiring harness that you would use to remove the door. Remove the plastic protective cover.
2. Unhook the wiring harness by manipulating the cam lock handle on the wiring plug to the door wiring harness.
3. Pull back the nylon sleeve on the wiring harness to expose the wires.
4. Remove the wrapped electrical tape wrapped around the wiring harness underneath the plug for the wires that go to the door.
5. Locate the purple wire with the peach colored tracer.
6. About 3 to 4 inches from the plug cut the purple wire with the peach tracer. (this will allow you ample room to solder the wire back together and apply heat shrink tubing over the wire if you decide to make this function work again), in the event that you sell your jeep.
