Passenger side blend door for temp control location?
FLJLU
2020 JLU
My passenger side a/c will only blow super cold, unless its set to full heat. I see the actuator for fresh air/recirc, I've replaced the diverter box actuator. Where the hell is the temp actuator for the passenger side? Parts diagrams don't show it.
Gregj
Greg
West Texas
I had to stand on my head in the footwell to find it. It is hiding behind the duct work for the floor vents. The duct just pops off and it is easy to get too. Be sure to put it in the park position before you install the motor.
Gregj
Eta it is down by the bottom of the dash
FLJLU
2020 JLU
Gregj
Managed to get the actuator replaced. Still have the same issue:
HI = 100% heat
84 or less = 100% LO
I watched the actuator before I installed it and when going from HI to 83, it slowly rotated to full cold in 5deg or so movements on its own. I wonder if there's a temperature sensor issue on that side.
Gregj
Greg
West Texas
HI = 100% heat
Try running it for a while, it may be going full cold to cool the cabin down and then it will stabilize when the target temp is reached.
Gregj
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Man I was just about to respond to the OP to let you know the actuator won’t fix the issue. FCA uses dumb actuators with no position sensing feedback. The learning and thinking happens in the hvac module. Good thing the actuators are cheap.
You’re probably onto something with the interior temp sensor. Do you have a scan tool that can read body / hvac data?
FLJLU
2020 JLU
I don't unfortunately. My thinking was the system doesn't seem to know what temp to be so it just defaults to hot and cold with nothing in between on that side. That line just happens to be HI and 83. Once my work schedule settles down I'll end up taking it in unless another idea presents itself.
FLJLU
2020 JLU
Gregj
Holy crap I think you were right. I set it to auto at 72 yesterday and now the cold output on each side is the same.
dbin
Frank
2019 jeep wrangler jlu
Sorry for the late ask. Did solve your issue?
FLJLU
2020 JLU
Ended up being a bad temp sensor in the air duct on the passenger side, fixed under my extended warranty. They likely had to pull the whole dash to get to it.
dbin
Frank
Okay thank you
