Painted my steering wheel Bezel and Dash
weagle93
Randy
Maryland
2019 JL Sport
That looks awesome. I think the painted steering wheel bezel really adds.
blnewt
New Mexico
Just ask @cosine he knows!
Great results! You use Mopar rattle cans w/ clear coat?
Gregj
Greg
West Texas
JLU Rubicon, JLU Sport, JTuRD
Wow! Looks pretty cool! You painted the Speedo and tach bezels black to match the a/c vent bezel’s?
Gregj
Varilux
Pete
Hickory Creek, TX
2018 Jeep Wrangler Rubicon
Nice work! +1 on the steering wheel bezel really setting it off.
If I didn't have the red Rubi dash, this would be on my "to do" list for sure (even now tempted to paint the speedo and tach rings black).
cosine
NY
2019 Wrangler Sport jl
Gone Postal
looks great. was the pieces snap on or screwed in.
Krondor
Gary
2018 Jeep Wrangler JL - Punk'n Edition
Oh that does look good.
I do like the steering wheel and bezel changes. Great work!
Bskylerj
Spokane, WA
2003 Jeep Wrangler, 2011 Chevy Avalanche, 2012 Hyundai Sonata
Gregj
Yes I did.
maustin
Vicenza, Italy
2020 JTR
Looks great! I plan on doing the same to mine. What was the process to remove the steering wheel?
Bskylerj
Spokane, WA
Disconnect both grounds on the battery and let sit for 20-30 mins. Small pick screwdriver to pull the caps on the back of the steering wheel.
10mm socket to take the bolts out on each side under the cap you removed. The center of the wheel will come out. You will need to unplug the airbag and set it to the side.
You will need a T10, T15 and a T20 torx screwdriver to get all the screws out for the bezel and controls. There is a black spacer right next to each sides controls. They are in tight but the slide out.
When reinstalling the airbag be careful on how the wires are run and don’t over tighten the bolts holding it in. It sucks it down tight and the horn stays on. Lol.
Hopefully this helps
maustin
Vicenza, Italy
2020 JTR
Thank you! That actually sounds way easier than on the JK where you had to pop the three clips under the airbag at the worst possible angles.
