I’ll show you mine, show me yours.Where all my firecracker red brothers and sisters at?
What are you doing getting my Jeep so dirty! HAHAHAI’ll show you mine, show me yours.
For all intents and purposes, it is still a bone stock rubi. Mud/dust coating the wheels, but since you mention it I don’t dislike the color!What are you doing getting my Jeep so dirty! HAHAHA
I have to live vicariously through you, I don't have mine yet!
I ordered the black hard top, but did get the painted fenders, that looks good. Are those the stock tires and wheels? I think those are the stock wheels, but yours are gray?
It looks like a lift as well? Are my eyes deceiving me? Yours looks really good, I intend to keep mine stock for a while - or at least as long as I can!
Wranglers are not really the best vehicles for snow on roads (although much better for deeper fresh snow off road). I would recommend getting a good set of snow tires. If you have the optional Limited Slip Differential that certainly helps with traction control but with Solid axel Wranglers and only one power wheel per axel they can struggle compared to many independent suspension all wheel drive verhicles. This also apples to Rubicons as lockers are useless in snow as they tend to bind and break traction. Also with the Cold weather FORM issue that prevents you from using electric power at times the 4xe is not the best in winter condistions. Plus the added weight does not help. This is why snow and ice specific tires are important for those that deal with more than occasional snow. I own a 2018 JL and a 4xe I also have a plow blade that I used on my JL, last year I installed it on my 4xe, then put it bacl on my JL as the 4xe really struggled with it compared to my 3.6 JL. which is set up for snow.Picked up less than a week ago- 4XE sahara with the one-touch soft top. I prefer black fender flares, so will likely do that over the next 6-12 months, and some decals to make it unique, but it will primarily be my daily driver in snow country, so I probably won't do much with the tires... (Open to advice, of course...)
That makes sense. Where we are moving the snow isn't nearly as bad as where I grew up (but definitely worse than Las Vegas, where I live now). More intermittent and usually gone within a few hours. For me, it's about ground clearance. I did note that in the 2023s (which this is) there is now a 4H made for roads that functions more similarly to AWD. Snow tires are on the purchase list!Wranglers are not really the best vehicles for snow on roads (although much better for deeper fresh snow off road). I would recommend getting a good set of snow tires. If you have the optional Limited Slip Differential that certainly helps with traction control but with Solid axel Wranglers and only one power wheel per axel they can struggle compared to many independent suspension all wheel drive verhicles. This also apples to Rubicons as lockers are useless in snow as they tend to bind and break traction. Also with the Cold weather FORM issue that prevents you from using electric power at times the 4xe is not the best in winter condistions. Plus the added weight does not help. This is why snow and ice specific tires are important for those that deal with more than occasional snow. I own a 2018 JL and a 4xe I also have a plow blade that I used on my JL, last year I installed it on my 4xe, then put it bacl on my JL as the 4xe really struggled with it compared to my 3.6 JL. which is set up for snow.
All the 4xes since the 21 release have gotten the MP3022 Full Time Transfer case with "4 Auto" to my knowledge.That makes sense. Where we are moving the snow isn't nearly as bad as where I grew up (but definitely worse than Las Vegas, where I live now). More intermittent and usually gone within a few hours. For me, it's about ground clearance. I did note that in the 2023s (which this is) there is now a 4H made for roads that functions more similarly to AWD. Snow tires are on the purchase list!
