Sboden
Kansas City
2020 Silver Willy's JLU 4d Mopar 2" Fox lift, 37's
I love it, Looks sharp. The larger rim might be an uncomfortable ride but still looks nice.
So if that is a spring lift you only gained .5" of lift. Rubicon springs are 1" longer than basic OEM springs. So basically you removed a 1" lift kit for a 1.5" lift kit. If its spacer then you obviously gained 1.5 inches.
As I understand it, the lift kits out there are giving numbers if put on a Rubicon. If you get a 1.5 inch lift kit, you are supposed to gain 1.5 inches with a Rubicon. You would get more with a Sahara or Sport. This is the reason why Sports and Sahara's need more components to get the alignment right even though lifting 1.5 to 2 inches.
lightsout
Gary
Seattle
Same lift you have Teraflex ST1 spacer. The 35's I am 9" tire to flair on all 4 (bumper and winch also dropped the front 1/2" more). The Rims are 18's with 35's I had them on my JL that only had 7K miles. Here in the PNW not much need to air down but I still do OK at 16-18lbs I was going to go to 37's and 17 wheels however I will be towing behind a Class A DP and managing weight is everything when towing. I am about 600lbs over weight as it is with the 35's.
eLECTRICON
eLECTRICON
Shane
PA
www.facebook.com
2021 Rubicon 4xe
Law Enforcement
  • Thread starter
  • Thread Starter
  • #154
I have the RT3 short arm kit.
eLECTRICON
eLECTRICON
Shane
PA
www.facebook.com
2021 Rubicon 4xe
Law Enforcement
  • Thread starter
  • Thread Starter
  • #156
May bad I confused you with another person using the eLectricon name that install the the ST1 with 37's
I added 1" spacers to the rear springs for weight compensation on top of the Teraflex, so that's probably what you read. I measured for spring compression. It was 3/4" compressed so I added 1" spacers to over compensate for when I throw gear in the cargo area.
lightsout
Gary
Seattle
I was going to do with a Spring and shock lift however I will be towing this behind a Diesel Pusher and had it weighed yesterday and it came in at 5900lbs. Most under 40' Motorhomes both gas and diesel have a 5000lb limit. There are exception like Super C but I was shocked at the weight with the 35's and my mods. I still have a set of Teraflex LCA's and Track bars to install. I am nearing the GVRW without cargo.
HungryHound
Rick
TN & FL
1975 CJ-5, 1983 CJ-5, 1987 YJ, 1998 TJ
My old 2000 Winnie with a 350 Cat was rated at over 10,000 lbs towing and it was only 38'. It was on a Freightliner with an Allison and pre-DEF, tho. Wonder what changed?
HungryHound
Rick
TN & FL
Good to know. That had me a little confused too. Do we really need a lift on a Rubi to get 35s under it?
alpha1847
Angelo
Boston, MA
2021 Wrangler 4xe
Had my Sahara for about a week now. Was hard to find all the options I wanted (basically everything - Skyslider, limited-slip, trailer tow/HD electric, cold weather, both security pkgs, proximity entry), so found one in-transit and jumped on it. Sting Grey wasn't my first choice initially, but when I saw it in person, I'm glad I went with it. Replacing a Mustang convertible and couldn't be happier.
Sboden
Kansas City
You don't but it will hit at the extreme range. It shouldn't be any issue for mild trail and street use.
lightsout
Gary
Seattle
The transmissions changed... the 5000K limit on the new Class A DP' are the Allison transmission. Like everything they are trying to keep cost down and most Toads are below 5K (even non 4xe Wranglers of previous years. I get it why would the RV industry over build for a select few towing more than 5K. However every car is going to start getting heavier with the electric generation, hell my Tesla Model S weights over 4K lbs. I figure I can get the weight down to 5200-5300lbs where that is likely fine and we will disconnect and drive the TOAD separately over any mountain passes.
Diode Dynamics
