My wife's setup is identical to yours. I extended the tail gate bumpers so the tire is snug against the rubber. She doesn't take this jeep off road but we've had no issues. I do check it occasionally, no rattles, hinge drop etc.Hi I was curious to know if its necessary to put an oversized tire carrier and tailgate reinforcement on a 2019 sahara? I currently run 35s with stock carrier, rc relocation bracket and stock tailgate.
I plan I driving across the country.
Thank you
I've been running a 17" beadlock and 37's on my MOPAR carrier and reinforcement bracket for a while now. I've been wheeling across the country with no issues at all. You'll be good to go, but getting the rubber stopper adjusted for your wheel/tire set-up is vital for everything to be OK.Hi I was curious to know if its necessary to put an oversized tire carrier and tailgate reinforcement on a 2019 sahara? I currently run 35s with stock carrier, rc relocation bracket and stock tailgate.
Thank you
What does this actually reinforce? Are you not just adding more weight to the tailgate by adding this? Not being a smart ass. I just don't see the benefitRC also has a reinforcement kit which would complement the riser and is reasonably priced. Check it out.
https://www.roughcountry.com/jeep-j...nd=2018-jeep-wrangler-jl-unlimited-4wd-378974
Looks like it should work to me may not be the best and beefiest option but definitely is stronger as it implements more mounting bolts to stabilize the gate to the actual hinges.What does this actually reinforce? Are you not just adding more weight to the tailgate by adding this? Not being a smart ass. I just don't see the benefit
Sounds like you have some options, we offer the Jeep carrier. Let me know if you have any questions.Hi I was curious to know if its necessary to put an oversized tire carrier and tailgate reinforcement on a 2019 sahara? I currently run 35s with stock carrier, rc relocation bracket and stock tailgate.
Thank you
So maybe I am confused. Is the point to get weight off gate or hingesLooks like it should work to me may not be the best and beefiest option but definitely is stronger as it implements more mounting bolts to stabilize the gate to the actual hinges.
I just recieved the Rugged Ridge kit yesterday. The hinges are super stiff and nearly impossibly to move. A bunch of WD40 and a mallet was the only way to get them to move. Are yours like this as well?there is only two options that actually change the hinges and actually reinforce the gate if you ask me, I just received the Rugged Ridge setup, will post some pics and info once I get it installed. I run a 35 with a 315, but the aftermarket rhino wheel I am holding is really heavy. It does not move off road etc, but I can see the sag already from the weight over time. I would invest in the evo or the rugged ridge setup and get the actual new hinges if you plan on off-roading, but all the others will work if you don't plan on upgrading the tire wheel size or off road much.
https://www.northridge4x4.com/part/tire-carriers/3032b-evo-manufacturing-hd-hinge-tire-carrier-black
https://www.northridge4x4.com/part/...ugged-ridge-tire-carrier-and-brake-light-ring
Will let you know, mine is getting delivered in like an hour or less, that would suck! but I am guessing after some use they will swivel pretty good. Have you contacted the manufacturer?I just recieved the Rugged Ridge kit yesterday. The hinges are super stiff and nearly impossibly to move. A bunch of WD40 and a mallet was the only way to get them to move. Are yours like this as well?
Keep me posted for sure. I planned on installing today but will hold off to hear back.Will let you know, mine is getting delivered in like an hour or less, that would suck! but I am guessing after some use they will swivel pretty good. Have you contacted the manufacturer?
