JeepFan
Interesting, but you ordered a 4 door Sahara and Select-Trac. I wonder if A/T tires and/or Dana 44 come with LSD on a 2 door Sport or Sport S?Order sheet with AT tires and LSD:
No. It requires the anti-spin rear differential.Can you get SelecTrac without getting the anti spin rear differential? Or is it required package deal?
Now I’m worried maybe there was a glitch in the ordering system? I went into it expecting that the upgraded rims would be required, but it let the dealer put through the order as shown...Well that is interesting because it doesn't match the order guide where it clearly says you can't get the AT tires with the default wheels (WHG). And there is no dependency for Anti-Spin. This would actually be good news for me if it is true.
When I build and price on jeep.com it allows you to have only SelcTrac without anti spin rear differential.however when I went to build with the dealer he said it was automatically packaging in the anti-spin rear differential when selecting the SelecTrac option.No. It requires the anti-spin rear differential.
See post #339 here:When I build and price on jeep.com it allows you to have only SelcTrac without anti spin rear differential.however when I went to build with the dealer he said it was automatically packaging in the anti-spin rear differential when selecting the SelecTrac option.
Please can anyone clarify?
I am pretty sure to have the full time four wheel drive that SelecTrac gives you, that you must have the limited slip rear to avoid binding, but that is my understanding and I am no expert.When I build and price on jeep.com it allows you to have only SelcTrac without anti spin rear differential.however when I went to build with the dealer he said it was automatically packaging in the anti-spin rear differential when selecting the SelecTrac option.
Where are you seeing this changed 31?Unfortunately I don't think this is true anymore. The Order Guide has changed.
It looks like to get the All-Terrain you need the upgraded wheels.
Can anyone confirm if they know differently?
See the order guide above. I went back and the order guide did change since 12/4 (see below).Where are you seeing this changed 31?
tbh it's confusing. ig we'll know soon. i saw another mistake or error on the wrangler features "interior page" where it shows the 2 door sport having no 12v in the rear of the center console while the 4 door sport having the 12v. then in the specs page it lists 2 12v for each model, 2 or 4 door. i wish i knew what was accurate...See the order guide above. I went back and the order guide did change since 12/4 (see below).
In the 12/4 order guide it said you need to have the upgraded tires. And the upgraded tires say you need limited slip or upgraded wheels. But the upgraded tires also said they couldn't be ordered with the standard wheels. So very confusing.
In the newer order guide there is no link between limited slip and the upgraded tires. They just require the upgraded wheels.
I asked on the dealer thread for clarification but he did not answer.
The Jeep.com configurator has been changed. Now when I build a 2 door Sport S and add limited slip differential it does say that it includes Dana 44 and A/T tires. However, when building a base Sport and adding LSD it says that includes A/T tires but doesn't mention the Dana 44?Interesting, but you ordered a 4 door Sahara and Select-Trac. I wonder if A/T tires and/or Dana 44 come with LSD on a 2 door Sport or Sport S?
According to the Order Guide it includes it. Same axle as on the Rubicon.The Jeep.com configurator has been changed. Now when I build a 2 door Sport S and add limited slip differential it does say that it includes Dana 44 and A/T tires. However, when building a base Sport and adding LSD it says that includes A/T tires but doesn't mention the Dana 44?
