Oracle reverse lights hooked up to reverse and switch? Can it be done???
Jeepjayjeep
Jason
Ontario, Canada
2020 JEEP RUBICON UNLIMITED RECON SPECIAL EDITION
lights would be awesome on a switch too
thanks
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
thanks
Absolutely! With the use of a diode and/or relay you can switch the lights on with your reverse light wire or Aux switch as a trigger.
There are already some good threads on the forum describing this in detail.
Jeepjayjeep
Jeepjayjeep
Jason
Ontario, Canada
Wild!!!
where would I look?
thanks
Htfan
Orange County, CA
Jeepjayjeep
Jeepjayjeep
Jason
Ontario, Canada
I’m not that great at electrical
i need a full diagram to tap into 2020 jlur reverse lights to a second switch up front. Book for dummies... showing all parts and electrical flow. Lol I’ve searched and can’t find diagram...
Jeepjayjeep
Jeepjayjeep
Jason
Ontario, Canada
Like this? No diodes? just relay?
Htfan
Orange County, CA
With a relay, a diode becomes optional on the switched circuit. However, may still be necessary on the auto circuit.
Will_Jeep
Will
Atlanta
Black 2108 JKU Sahara, Black 2016 Mercedes CLS400
If you look through this thread, it’s fairly long, (https://www.jlwranglerforums.com/forum/threads/backup-lights.10763/) you will find people who have wired up to both aux switches and reverse lights. Most folks went with diodes, in particular a dual input single output version, like this one https://www.etrailer.com/Accessorie...8pQUXLbLuBRIi6HkhwJyzwpwMBSYF7ZQaAh9jEALw_wcB
I haven’t done this myself, I just wired a couple of rock light directly into my reverse light circuit.
Rhinebeck01
Multiple places..
@Htfan
Actually, you'd need 2 diodes in the mix... and no relay needed, if you use Aux switch.
Htfan
Orange County, CA
@Htfan
Actually, It's really personal preference. Some people use relays if they believe their Aux lights require too much amperage for the factory reverse light wiring. For the switch, no need for a relay/diode.
In my case, two diodes did the job since only 18w x2. I also added an inline fuse just in case.
Jeepjayjeep
Jeepjayjeep
Jason
Ontario, Canada
So I can use a relay like in drawing and add two diodes, one going in between switch and factory reverse light and the other one? Thanks
Rhinebeck01
Multiple places..
Do your homework carefully. A tad of misinformation being spewed in this thread.
monkey6
Korie
Augusta, Georgia
2018 JLUS 2.0T, 2021 JTM
It's pretty easy to hook up a relay. I did it to wire a 10" light bar mounted under the bumper to come on with the reverse lights. I think it was a brown wire on the taillight harness that I tapped into, but check the wiring diagram. I tapped into power at the 12V outlet in the back for power. All the wiring is hidden under the driver's side plastic panel in the rear, and the power and ground are routed down to the bumper through the rubber grommet that is already there. I plan to switch to the oracle bumper lights soon and I'll use the existing wiring that I have in place for that light.
