adamk
- Adam
- Jun 3, 2020
- Charlotte, NC
- Jeep Wrangler JL Sport S Altitude
- Vehicle Showcase
- 1
I recently purchased a Sport S and have started a long list of mods, starting with the lighting. I really wanted LED lights, so decided to purchase both the Oracle LED headlights and taillights- the latter being a quick and easy install. I wanted to share my headlight install notes, as I ran into some difficulties but ultimately got everything up and running. Disclaimer - never have worked on a car in my life, so by no means an expert.
Before and after photos, along with some install notes and pictures.
Before
After
I dont know if I was just being too gentle with the grill, but it felt like this thing was going to break in half before I could get it off. Eventually yanked the thing off without breaking anything thankfully, but wanted to share the clip locations for those of you new to getting this thing off. It helps if you can get your hand behind the grill, closer to these points, before pulling.
Disconnecting the existing lights takes only a few minutes, and running the wires through the engine bay is as difficult as you choose to make it. I ran the driver lighting cable near the upper radiator, where there were already cables. Zip tied it to the existing cable.
Where I ran into most of my issues was with the connection to the frame and fuse box. I quickly discovered that the wire to the fuse box was not as long as in the available install videos. All the videos I found recommended drilling a hole in the back, however the wire wouldnt reach the F52 slot. I had to drill into the front, and it barely reached the slot.
Also had some trouble finding F52, because I assumed there wouldnt be a fuse there. Wrong assumption - eventually figured out you have to pull the 20 Amp fuse, and plug it into the provided adapter, along with the 5 Amp fuse in the Oracle kit.
In all the movement to get the wire to reach, I actually severed the grounding ring eyelet from the cable. I know this was more install error, however wish there was a better connection to the ring eyelet. As a short term fix, I took some 15 Amp wiring, cut and stripped both ends, and then created a jumper between the body bolt and the Oracle adapter. I realize this is interior wiring, so thoroughly wrapped it with electrical tape and hope that will suffice. May eventually replace with something else, but did the job and lighting works.
Overall was not a difficult installation but for someone with little car knowledge, seems like there are some important steps not mentioned and/or clarified. Love the head lights, and will eventually hook up the RGB lighting once the Bluetooth controllers are back in stock.
P.S. - snapped below image before I realized I had wrapped the grounding wire to the wrong bolt. I moved it over during installation but forgot to snap a pic.
Here is a quick pic of the Oracle LED tailights.
Before
After
