ORACLE Oculus Bi-LED Headlight Upgrade for the Jeep JL / JT
Status
Not open for further replies.
10mmauto
Western NY
2021 Jeep Wrangler Willys, 2008 Mustang Bullitt
LEO
So I went out today and grabbed a picture. Sure enough, if you look hard enough at the inside of each light, there appears to be a slightly greenish tinge. I think it is an optical illusion. The outsides are a nice, bright white.
Anyway, I am very happy with these.
Deadserial
Justin
Eugene, OR
2019 JLU sting gray sport s
I just got mine yesterday and install was a breeze. Took me 45 mins total. The connections from the headlights and build quality of the headlights are definitely top notch, very impressive! My only gripe was the positive and negative pigtails are not split out far enough to run through the fuse box where you can actually shut the lid. I’ll either have to drill a hole in the lid or solder a longer section of wire. The halo color does have an odd hue that doesn’t match any of my other LEDs... but I am a bit on the OCD side so to most they probably won’t even notice it. Light output is great, tons of color flicker and colors on the band which looks cool coming at you. I’ll give them a 9/10!
Deadserial
Justin
Eugene, OR
Little update after having them for a day. Light output is pretty good. Not quite as good as some HID setups I’ve had, but still much better than halogen. I have a sport S on 33s and the height is darn near perfect out of the box. I noticed after getting my grill back on, the halos seemed a bit dim to me. Then I realized, I have aftermarket black headlight and grill rings And that little extra bit of material actually blocks about half of the halos circumference. I’m not sure if Sahara’s or rubicons would have the same issue or not. I wasn’t fully sold on the look so I’ll probably pull the rings off regardless.
blnewt
New Mexico
Just ask @cosine he knows!
What other HID setups have you had? My Infiniti Xenons have a better output & cutoff than any Jeep LEDs I've seen FWIW.
Deadserial
Justin
Eugene, OR
I’ve done dozens of retrofit headlights and had 25 cars so I’ve had a lot to compare with. The best car from the factory I’ve had was a Honda S2000. Retrofits I’ve done, the best was probably the g5r projectors with 45watt ballast and osram CBI bulbs. I put them in an xterra...
Deadserial
Justin
Eugene, OR
Removed the headlight rings and you can actually see the whole halo now! Still not in love with the color of them. I have diode dynamics switchback fender leds and factory led fog lights as well. The switchbacks are a pure white and maybe a tad bit of blue. I’d say 5500k. The factory fogs are about 6000k. These don’t look close to either of them. It’s about a 5000k with a slight green hue. It’s just an odd color I haven’t seen from an LED before. I’ve installed a few halos, morimotos/ diode dynamics, vleds, and these don’t look like any of them. They do look less green at night, but still noticeable compared to others. I parked next to a rubicon with led package and their halos looked much more crisp and white/blue.
shekmark
Manasquan, NJ
Yes
I like the color.
BillJeep
Bill
Yardley
2019, JLU Sahara
Just installed these and like everyone else said, install was a breeze. The pigtail split length was the only thing I wish changed - seems like everyone having same issue there.
Gap between grill and lights is a bit more than I’d like, but maybe this is normal - - anyone else have the same?
Overall, very pleased with the purchase so far. Just getting cold here in PA so will be able to test it out in the snow soon enough. Was raining last night and the were great.
Deadserial
Justin
Eugene, OR
That gap looks the same as mine, and normal. I think with the halos extending so far out to the edge it’s probably best that that gap is there. If you really want to you could throw some washers between the mounting tabs and frame when you install them and space them out a little bit.
Jeremy
Northwest indiana
@Oracle is the color of the halo expected to appear different than the OEM LED headlights?
Varilux
Pete
Hickory Creek, TX
2018 Jeep Wrangler Rubicon
Ordered Oculus Bi-LED headlights on Cyber Monday and installed them today. I could not be happier with this product! It is obvious someone has put a LOT of thought into the design of this product. If I had my own factory I can't imagine anything I would do differently (well, I might make the red wire for the halos 2" longer, but they were still the perfect length once I removed about 2" of the rubber surround connecting the ground and red wire- after doing that, the red wire was the perfect length). I have the stock 33" tires, and the beams were adjusted spot on out of the box.
Since I knew I was going to be removing the grille, I went ahead and bought the Gladiator grille inserts. Even with the time it took to remove and replace the inserts, the install took under an hour. I will be buying all my lighting from Oculus from here on out (it would be REALLY nice if you made some matching off-road lights I could swap out to :^).
I have the LED fog light bulbs on order, but they are on backorder for a couple weeks yet...
zmanz28
Zman
Minnesota
2018 Jeep Wrangler Sahara
I live in Minnesota. Do they ice over in snow/ice storms?
Status
