Yes that is with headlights on auto and DRL marked as on in Uconnect. I am assuming it is because I don’t have the factory LED, they run with my headlights on always.As @mwilk012 said, I believe halos turn off when the headlights come on.
Is this picture with the light switch in auto?
Wondering if this is happening because you don’t have LED package, or did Oracle give you direct instructions to use that white and brown wire?
I also could be 100% confused about the halos ff when headlights come on thing, but for some reason I’m remembering someone saying the halos come on automatically even if the light switch is in the off position.
Hi,There are three bulbs in there, with DRL in the middle. The factory LED bulb I believe changes from amber to white so the light is more even across the fender, but someone else may verify or refute.
Here is what happens in each position with the vehicle in park. I can’t say if anything changes while driving, because well, I’m driving.
Auto position (in the dark): DRL, headlights and halos all on
Headlight on position: all three on
Parking lights only on: halos and DRL’s on
Lights off: only DRL no halo
Unlock: headlights only come on
Remote start: DRL and halo only
There could be some setting in uconnect, but I have DRL’s set as on.
You bet, and thanks for watching! Neither the DRL nor halo turn off with the turn signal. I wonder if this has something to do with the two positive wires leading the DRL bulb. ORACLE will be releasing a DRL very soon that has the Amber turn signal and white DRL.Hi,
Thanks for posting this. I frequently watch/like your YouTube channel, among many others.
Question - When you put on the turning indicator, does the corresponding Halo ring go off with the DRL on the turning direction side?
They don't though, only in Canada do the DRL's stay on when headlamps are on. And when the Turn signals are on, the DRL on that side turns off. Something strange is going on with yours. You can also have the foglights on independent of the headlamps with the switch in the parking lamp position, and the DRL stay on.Yes that is with headlights on auto and DRL marked as on in Uconnect. I am assuming it is because I don’t have the factory LED, they run with my headlights on always.
I figured the wire out in my own. I actually tested both wires and I am not sure abt the other is for, but this is the one that works.
I have a halogen JLUS (in the US) and my DRLs do stay on with my headlights. They actually DIM when I turn the headlights on. I'll also add that when I installed aftermarket LEDs in the DRL fender position, they needed to be low input models. My initial attempts (without the low input bulbs) did in fact turn the DRL off when the headlight was turned on.They don't though, only in Canada do the DRL's stay on when headlamps are on. And when the Turn signals are on, the DRL on that side turns off. Something strange is going on with yours. You can also have the foglights on independent of the headlamps with the switch in the parking lamp position, and the DRL stay on.
