Oracle LED Headlights High/Low Inversion?
WranglerMarty
Marty
Wisconsin
2018 Wrangler JLU Sport S
Has anyone that has installed the Oracle LED headlights had this problem? The high beams are on the default, and the low beams only come on when the high beam setting is activated. Any fix?
Skippy
Aaron
Minnesota
2018 JLUR, 1996 Ford Bronco 351W
I havent had this issue with these exact lights but in the past I have had that issue. I found that sometimes when they get assembled the high and low beam wires are crossed over. Although that was also in an H4 style bulb. I dont recall what wires these lights have. Simply put you might just need to remove the back plug of the headlight wiring and switch the low and high wires.
WranglerMarty
Marty
Wisconsin
  • Thread starter
  • Thread Starter
  • #3
Thanks! I went ahead and repinned the two wires on them and it worked perfectly!
TopLift Pros
