Oracle LED for JL is pulsing a little
Goheels050917
Dustin
Raleigh - Durham, NC
2018 Jeep Wrangler JLU (SOLD - March 2021)
SD-WAN Engineer - Technical Author
Howdy!
I've had my oracle LED bulbs in my headlights for 6 months or so and I love them. However, I can see a hint of pulsing when its really dark outside and pretty much pulses when the engine is on. If does not flicker on and off, just a pulse.
I put in the resistors when i installed them, but has anyone who has ordered and installed seen this?
It's these in the link below:
https://www.oraclelights.com/products/oracle-2018-2019-jeep-wrangler-jl-led-bulb-conversion-kit
DaltonGang
Houston, Tx
Predictable, with aftermarket LED lights. The heat buildup from the sealed headlights will cause this to happen. I read up on this happening, with almost every maker out there, that has been out for a while. That is why i installed Philips H13+100 Halogen bulbs. Around $30, very bright, and zero issues. I have used them in other vehicles I own before this.
DaltonGang
Houston, Tx
Howdy!
Have you thought about getting a refund, or have them send new ones?
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Predictable, with aftermarket LED lights. The heat buildup from the sealed headlights will cause this to happen. I read up on this happening, with almost every maker out there, that has been out for a while. That is why i installed Philips H11 +100 Halogen bulbs. Around $30, very bright, and zero issues. I have used them in other vehicles I own before this.
https://www.amazon.com/Philips-X-tremeVision-Upgraded-Headlight-Vision/dp/B00U1OIESK?th=1
Are these the bulbs you used? I've been looking for an alternative to full LED housings given that LED bulb replacements aren't legal in my state.
DaltonGang
Houston, Tx
Aaron
Colorado Springs, CO
2018 JLU Sport S turbo. 2012 Road Glide. 2015 Chrysler 200s V6 AWD.
US Army
mwilk012
Oklahoma
Service
Ehh, fog lamps are so dim is almost not worth the effort to do anything less than add LED’s. Are you mostly looking for increased brightness or color temperature match?
Aaron
US Army
I'm just trying to get rid of the yellow color until they make a good replacement housing without having to buy an adapter. But i want the fog and head light colors to match
mwilk012
Oklahoma
Service
Fair enough, I only had to look for halogen headlamps because it is illegal(ish) in my state to use led bulbs in halogen housings for headlamps specifics. I doubt anyone is going to design a light with a housing that matches up to the oem bumper because it’s just not worth the R&D.
Aaron
US Army
It doesn't necessarily need to be LED i'm ok with the brightness of the halogen on both set i just want the yellow color gone. What do you recommend for a matching set ?
