Oracle Jeep Wrangler JL “black series” LED Tail Light
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
ORACLE Part# 5852-504
*NEW PRODUCT ALERT*
Fitment:
2018-2020 Jeep Wrangler JL
Designed to fit all JL Wranglers without the factory LED package.
Aggressive Blacked-Out design featuring upgraded LEDs for all tail lamp functions including Driving Lights, Brake Lights, Reverse Lights, and Turn Signals. Add the Premium-Style hour-glass LED design to your JL Wrangler with these new LED Tail Lamps from ORACLE Lighting. Easy Plug-and-Play installation, plugs directly into the factory JL tail light socket. Load Equalizers are pre-wired so no warning lights on the dash will occur, just install and drive! Durable IP67 waterproof rating, designed to fit all JL Wranglers without the factory LED package.
Features:
- Black Bezel Color with Smoked Lens.
- Premium Performance High-Output LED's.
- Corrosion-Resistant Coating.
- Heavy Duty Solid State Electronics.
- Hard-Coated Poly-carbonate Lens.
- Easy Plug & Play Installation.
- Will NOT cause warning dash light. .
- 1 Year Warranty
Installation Video here:
YippieKiYayMrFalcon
Rob
Atlanta
2021 JLU 80th Anniversary
Can you get these in non smoked?
I’ve been looking for ones that are the same color pattern as OEM and can’t find any. Oracle and others only seem to have the smoked ones.
Quake does have “redout” ones, but they’re more clear than red. Not sure why the after market hasn’t just made “normal” ones yet.
lanman08
landon
wilmington, nc
2018 Jeep Wrangler Unlimited Sahara JL
Been searching for the same can’t find them anywhere!
ORACLElights
ORACLElights
Metairie, LA
Party Marty
St. Louis, MO
2019 Wrangler Unlimited Sahara 2.0
Lol, I had never been in the "lighting" section before, and this was exactly what I was coming to find..."Can I get an aftermarket tail light that looks similar to OEM?" Sure seems like it's a no at this point. What gives?
blnewt
New Mexico
Just ask @cosine he knows!
IMO the smoked looks better than the OEM, and the light output and visual is the same. Maybe they aren't available in a non-smoke finish is there would be patent infringements (if that even matters to foreign manufacturers anymore).
ORACLElights
ORACLElights
Metairie, LA
Y’all got a coupon code for these? I might order a pair.
Yes! You can use code forum10 for a discount on OracleLights.com :like:
Mr.Smith
East Tn
2024 Rubicon X
Do you have a smoked that are replacement for folks with factory LEDs already
ORACLElights
ORACLElights
Metairie, LA
We don't, but we will pass the note to R&D!
