Options for carrying a canoe/kayak
  1. ashleylynn1220
    ashleylynn1220 New Member
    First Name:
    Ashley
    Vehicle(s):
    2018 Wrangler JLU
    Jan 4, 2019
    Highgate, Vermont
    Liked:
    Could you please tell us what this set up is?
  2. Mailmanj4
    Mailmanj4 Active Member
    Vehicle(s):
    2018 JLU Rubicon
    Apr 7, 2018
    Oregon
    Liked:
    Yakima raingutter rack with Yakima sweetroll kayak mounts/saddles. https://www.yakima.com/sweetroll
    TCogs1 likes this.
  3. Mailmanj4
    Vehicle(s):
    2018 JLU Rubicon
    Apr 7, 2018
    Oregon
    Liked:
  4. ashleylynn1220
    First Name:
    Ashley
    Vehicle(s):
    2018 Wrangler JLU
    Jan 4, 2019
    Highgate, Vermont
    Liked:
    #109 Jan 10, 2019
    Great thanks! How do you like the set up so far? Just curious how you got two kayaks up there with the sweet rolls...it's saying a min of 24" between brackets so wondering if both of my kayaks will fit up there...mine are 29.5" wide. So I'm guessing both of mine might not fit since the crossbars themselves are usually 60". I am thinking of going with the Thule Aeroblades instead of the Yakima raingutter rack that you used.
  5. Mailmanj4
    Vehicle(s):
    2018 JLU Rubicon
    Apr 7, 2018
    Oregon
    Liked:
    I like the setup a lot. Mine are 31” wide. They are snug but fit nicely. There isn’t much play on the outside of the mounts, with the cross bar, but enough that I have never had any issues. I have driven at freeway speeds and all was well. The tie downs cinch in really tight so the kayaks don’t get loose. I have door steps that help me get high enough to secure everything. The only drawback is the noise from the rack, especially when the kayaks aren’t mounted.
    ashleylynn1220 likes this.
  6. Akbill
    Akbill Well-Known Member
    First Name:
    Bill
    Vehicle(s):
    '19 JLUR
    Aug 18, 2018
    Alaska
    230
    Liked:
    86
    I got the max 3 with long pioneer rack, I discovered that the Malone Downloader kayak rack fit perfectly and very low profile, I got some 8mm slot nuts and put 2" 8mm bolts into top of Malones with washer under bolt head, the rack needed a tiny bit of filing on one of the end pieces so it didn't hit the rack when opening/closing, but it works perfect. the Malones are mounted in slot of the first full width slat on each side of the rack for two kayaks. I use the Malone loaders to easily get the kayaks up onto the rack and back down.
  7. Achilleus07
    Achilleus07 New Member
    First Name:
    Richard
    Vehicle(s):
    2018 Jeep Wrangler JL 2 door
    Dec 6, 2018
    Atlanta
    Liked:
    Has anyone tried the https://www.etrailer.com/Hitch-Cargo-Carrier/Yakima/Y01149-1150.html long arm?
    I have 2 Vibe kayaks at 50lbs each/ 100 lbs together and I only transport them with roof off. I was thinking to place them on the Yakima longarm and then with a foam pad on the middle roll bar. Would this be ok? I only travel about 10 miles down the road 55 mph max. Thanks.
  8. multicam
    multicam Well-Known Member
    First Name:
    Tanner
    Vehicle(s):
    2018 4Runner, 2019 JLR
    Feb 11, 2019
    777
    Liked:
    1,340
    Garage Profiles:
    I used to just drop the top on my TJ and ratchet strap the kayak(s) down to the roll cage. But I guess that’s not an option with the hard top. Also I wasn’t driving very far, maybe 20 miles max.
    intentsrig likes this.
  9. Nzrubicon
    Nzrubicon Member
    Vehicle(s):
    2016 JK rubicon Anvil
    Dec 17, 2017
    New Zealand
    Liked:
    This is what i use with my JK rhino rack backbone system with 2 bar and a rhino rack t bar and a hitch extension 12" work perfectly.
    RikFlairWoo and Stretcher like this.
  10. @OUTDOORTREE
    @OUTDOORTREE Well-Known Member
    First Name:
    Bob
    Vehicle(s):
    2018 Rubicon JLU
    May 9, 2018
    Yakima, WA USA
    574
    Liked:
    870
    Garage Profiles:
  11. dspeir
    dspeir Member
    Vehicle(s):
    2019 Jeep Wrangler Sport S
    Apr 23, 2019
    WV
    Liked:
    Did you ever have any issues with hauling two kayaks?
  12. JL18
    JL18 Active Member
    First Name:
    Tom
    Vehicle(s):
    2018 Wrangler JLU Sahara
    Feb 24, 2019
    Birmingham, AL
    Liked:
    Anybody make an eyelet or something that replaces the front toe hooks, so I can tie a strap to it?
    Stretcher likes this.
  13. brazos
    brazos Well-Known Member
    First Name:
    Vehicle(s):
    2018 JLU Sport, Giant singlespeed mountain bike, Hobie Revolution kayak
    Apr 4, 2019
    933
    Liked:
    1,630
    Occupation:
    Dog Feeder
    Rob likes this.
  14. missnico
    missnico Member
    First Name:
    Nicole
    Vehicle(s):
    2019 Wrangler JL Unlimited
    Feb 11, 2019
    NYC
    Liked:
    Hey guys, traded in my coupe for a Wrangler JLU a few months ago and looking forward to getting out on the water soon. Last year I just used foam bars and ratchet straps that I picked up when I bought my kayak and it worked fine for short trips.
    I've been looking at picking up this rack (https://www.extremeterrain.com/rhino-rack-vortex-sg-2-bar-roof-rack-black-0717.html) and then just pop the kayak on top of that using the same foam and straps. I want to avoid scratching the top as much as possible. Could something like that work for a 10' kayak that is 44lbs?
    Also does anyone have experience with using something like this to load (https://www.amazon.com/Seattle-Sports-Sherpak-Boat-Roller/dp/B009PAAI5I?th=1&psc=1). It seems like it maybe works with trucks that aren't as boxy, but could maybe do the trick. I'd like to be able to get it on an off myself and I am only 5'4".
  15. slimfl08
    slimfl08 Well-Known Member
    First Name:
    Victor
    Vehicle(s):
    2019 JLU Ocean Blue Rubicon
    Mar 18, 2019
    Great Falls, MT
    86
    Liked:
    198
    Garage Profiles:
    Is there a reason you tied the canoe off through the door jams vs the rack? Im still awaiting my Gobi arrival trying to figure out best mounting options.
    @OUTDOORTREE likes this.
Loading...
Share This Page
