Opinions on the manual transmission
mgroeger
Hurricane, UT
2018 JLUR "Fat Ninja", 2020 Acura RDX A-Spec
Unbelievable. I tried this today, and it's like a whole new vehicle. Wouldn't have thought that disabling hill start assist would greatly improve off the line clutch feel, and also slow parking lot speed throttle control.
Wow, I can't wait to try this. How in the world does the brake assist being disabled effect the clutch?
unsavory
Jimmy
2019 JLUR
No idea, unless it's just a horrible implementation. No loss here, as my hill start assist wasn't working anyway.
mgroeger
Hurricane, UT
sf5211
Bronx N.Y.
New 2019 JL
Plumber
Hey guys, I wanted to also try shutting the Hill Assist to see if there's a difference. I've seen it before but for some reason couldn't find it this morning. Please refresh me on the steps. Thanks in advance.
unsavory
Jimmy
2019 JLUR
It's under vehicle settings, and then something like Safety and Assistance. Going off memory here, so might have the names slightly off.
WreckEm711
Lubbock, TX
2020 JL Sport 6 speed
Tried this, didn't notice any difference other than that I was stalling from a stop more easily so I turned it back on.
geem03
Gary
New Brunswick Canada
2019 Jeep Wrangler Sport
RN/ Firefighter
the recall is misdirected into believing the problem is brake hydraulic oil leak into the clutch assembly but the problem is obviously somewhere else when there is no oil loss and the clutch still smells just like burned clutch does
I still get that....
DanW
Indiana
The recall is because the clutch can slip and overheat and either blow apart or catch fire. So the solution is a heat shield on the clutch line. Personally I was thinking a better clutch would be in order but clearly I'm an idiot... lol.
As I understand it, the problem's root cause is due to air bubbles not properly bled from the fluid in the slave cylinder, not by a bad clutch. The clutch going bad is a symptom. The clutch is fine if it was properly bled. Other parts in the recall are to prevent a line from getting cut and leaking fluid catching fire in a catastrophic failure. With air bubbles, the clutch doesn't fully disengage under certain conditions, causing friction that generates extreme heat, wearing out the clutch and compromising in some way the metal in the friction plate which in the extreme, causes it to break apart and blow out of the bell housing and possibly cut the hydraulic line, causing a fire.
Again, that is how it was explained to me. Could be wrong or partially wrong.
Kluk Ztopolovky
Kluk
Toronto
Wrangler JL Sport 2dr Sting Gray manual
yes, that's what Fiat says but I don't necessarily buy that
Kluk Ztopolovky
Kluk
Toronto
Interesting , this "bubbles theory" is a new one to me and thank you for posting it . At the end of the day my clutch still smells and the recall inspection was performed by the local Fiat dealer . I kind of resigned and I will see what happens. If the clutch fails I hope it won't be during my next road trip and that's all.There is much bigger fish to fry these crazy days.
ChattVol
Tennessee
JLU 4 door
LOL, I was getting ready to call you to talk about this.
Turned off hill assist today. Starting from a stop felt a tiny bit smoother...but it wasnt a big difference. I like the hill assist when wheelin steep stuff...so I'll prob leave it on.
OceanBlues
Steven
North Carolina
2018 JLU Sport
About 50k miles, no issues. Just got a new clutch from the recall and still buttery smooth.
sf5211
Bronx N.Y.
New 2019 JL
Plumber
Thank you Jimmy
Next Venture Motorsports
