lightsout
This must be your first Wrangler, welcome.
As history has shown over the last few decades with YJ/TJ/JK, the clutch-based LSD doesn't have a long service life. The only exception was the 2003-06 Rubicon which had a torsen-style LSD. No reason to bury your head in the sand.
Such a moronic statement, I would love to see the published data on this, I am sure the lifetime powertrain warranty providers would have considered this elusive FACT. Is that 50K miles highway, 50K miles offroad, 50K miles snow/mud, or 50K miles, If I drove with lockers on 50K miles there would be issues also. The clutch is only engaged when activated/needed, whereas all clutches are subject to wear over time. There is NO published data on this just gossip from a forum. If you say 50K miles that would assume an average meaning many will fail premature to that 50K I am sure, no I am positive that No car manufacture would warranty a known failure within their warranty period including OEM or aftermarket.
This is my 3rd jeep as well as 2 land Cruisers over the last 35 years. Limited slip has been a reliable technology for may years and it has only gotten better just like Lockers and open diffs and every other mechanical component used.
I am not saying that LSD clutches do not wear outr however however 50K is not a hard number it can easily double that in some cases. Even then it is an inexpensive maintenance repair DIY can do it (clutch Pack) for under $100 and it is not a complicated thing.
My overall point the entire wrangler is subject to failure due to wear and tear over time not just the LSD. A road warrior may get 100-150K before needing a new clutch, others that live in a snow environment may need it in 1/2 that time. This is just like brakes the harder you use them the more maintenance they need. Lockers create more excessive wear on your tires as well so you should factor that in. Then again it is all subjective to actual use...
The fact is some people have more benefit from Lockers and others have more benefit from LSD and considering about a $4k difference in cost as little clutch maintenance at some distant point I could replace that clutch many times over for the cost difference...
