lightsout
The downside to lockers is on turns, they tend to bind causing a break in traction, which is why lockers are unsafe in snow and ice unless going in a relative straight line most of the time, same applies for mud. LSD provides that boost only when needed. By adding the Locker front with the rear LSD you have the best of both worlds when needed. Those that use say a Tazer on their Rubicons to by pass the 4-L only use of Lockers allowing then to be used in 4-H is not a wise choice and will likely created more binding opportunities or slippage on turns especially at higher speeds often driven in 4-H.
