mgroeger
- Mike
- Feb 1, 2018
- Hurricane, UT
- 2021 JLUR 2.0T, 1991 YJ rock crawler
- Occupation
- I make microchips for a living.
- Vehicle Showcase
- 1
Google and see video above.Okay, that's where I get confused about 4 wheel drive. In 2H, I thought and saw on the Jeep website that 100% torque is going to the (2) rear wheels. 50-50 aside. If slippage is indicated - BLD is applied and when clear, becomes 50-50 again. In 4H, the same thing occurs in the front and in the back, no?
So what you are saying, is in 2H, 100% torque is applied to (1) wheel (Left or Right?). When slippage is indicated, the BLD is applied and the torque is shifted to the non-slip side. This description is also applicable to the front, no?
To that end, would you ever see a limited slip differential with BLD added?
Would you have to remove one system to use the other?
So I was thinking about lockers on a D30/D35 Sahara, but that takes me in several rabbit holes.
I have a 3.45 rear end. Most lockers require 3.75 and above? Why? More importantly, if I want lockers will I have to regear? If I have to regear...will I need to "re-axle"? Joking of course, but nevertheless do you believe that the reason you don't see elocks on a D35 is because its not made to handle an elock? I have seen/heard of air-actuated locks on a D35, not sure why there is one over the other.
Sorry about the ranging questions!
