Jeepeto
- Josh
- Jul 24, 2021
- North Texas
- 2021 JLUR XR
- Build Thread
- Link
- Occupation
- Sparky
- Vehicle Showcase
- 2
Okay... I've given some thought to this, and I feel like a single switch solution could exists if I can find the correct relay. After a quick google search, I can find what is called an "alternating relay" available, but most seem designed to control 120V AC load, even if the relay itself operates on 12v.
From what I can tell, if these alternating relays behave in the way that I think they do, they would provide a single switch solution to the LP6 Hi/Low problem while using only one aux switch.
Please correct me if I'm missing something here...
If I understand it correctly, the alternating relay is designed to alternate between two loads at every power cycle. That is to say that the first time you press the aux switch (on), it would ignite the LP6 low beam, then you press the aux switch again (off) and it releases the relay, then the next time you press the aux switch (on) the relay would "alternate" to a secondary contact and ignite the LP6 high beam. This cycle alternates back and fourth and would mean that you could select high/low by cycling through the relay using only one aux switch.
I just need to find the relay I'm looking for... It's got to exist
